69 intake
Old December 18th, 2017, 02:38 PM
scrappie's Avatar
69 intake
How do you I.D. a 1969 Hurst Old intake manifold? Any Casting numbers or sure way to I.D.? I know there is something unique.
scrappie is offline
Old December 18th, 2017, 02:40 PM
stlbluesbrother's Avatar
It will have a "J" on the drivers side near thermostat housing hole.
stlbluesbrother is offline
Old December 18th, 2017, 02:51 PM
scrappie's Avatar
Would it be a recessed J or embossed? Are you sure drivers side? Any other numbers?
Do the casting numbers 398662 mean anything? I see one with a J on pax side of t-stat housing
scrappie is offline
Old December 18th, 2017, 03:09 PM
scrappie i assume your looking at the CL listed HO J intake? as mentioned the HUrst J is on the drvrs side the pass side J is the standard 4bbl intake no HO association.
Casting numbers are raised. Be aware that both the H/O intake and the run-of-the-mill 68-69 BBO intake have a "J", but in different places. The common intake is casting number 398662. The H/O intake is casting number 405233. Of course the H/O intake has the nipple for the PCV valve sticking up behind the t-stat crossover.
joe_padavano is online now
Old December 18th, 2017, 03:12 PM
Old December 18th, 2017, 03:18 PM
And THAT is the run-of-the-mill 68-69 intake, NOT the 1969 H/O intake. Note the lack of the PCV nipple. The nipple is located right where the "J" is in this photo, which is why the "J" is on the other side on the H/O intake.
Old December 18th, 2017, 03:21 PM
scrappie's Avatar
Thanks guys, just in need of a little education on that.
scrappie is offline
Old December 18th, 2017, 05:50 PM
thats the pic from the cl ad i assume scrappie is looking at for just $350 you can own that...ad states "sandblasted" ?...musta been some time ago ...
Old December 19th, 2017, 06:18 AM
A common 68-69 BBO intake isn't worth $350. A correct 1969 H/O intake is probably worth ten times that.
Old December 19th, 2017, 04:40 PM
classicmuscle442's Avatar
Have the 68-9 intake, the 398662 (D1 S) one with the J on pass. side of water inlet.
classicmuscle442 is offline
Old December 20th, 2017, 04:43 AM
Member
timholliday's Avatar
Here is an image of a '69 H/O intake.
timholliday is offline
TIM FISKUS
May 12th, 2013 05:17 AM
Wildcard
December 26th, 2012 07:48 AM
Nickyloves442s
October 24th, 2012 04:55 PM
svnt442
July 17th, 2011 04:43 PM
71cuttyS
October 31st, 2007 04:58 PM
Quick Reply: 69 intake
