69 intake
Old Dec 18, 2017 | 02:38 PM
scrappie's Avatar
69 intake
How do you I.D. a 1969 Hurst Old intake manifold? Any Casting numbers or sure way to I.D.? I know there is something unique.
Old Dec 18, 2017 | 02:40 PM
stlbluesbrother's Avatar
It will have a "J" on the drivers side near thermostat housing hole.
Old Dec 18, 2017 | 02:51 PM
scrappie's Avatar
Would it be a recessed J or embossed? Are you sure drivers side? Any other numbers?
Do the casting numbers 398662 mean anything? I see one with a J on pax side of t-stat housing
Old Dec 18, 2017 | 03:09 PM
RetroRanger's Avatar
72 Olds CS
scrappie i assume your looking at the CL listed HO J intake? as mentioned the HUrst J is on the drvrs side the pass side J is the standard 4bbl intake no HO association.
Casting numbers are raised. Be aware that both the H/O intake and the run-of-the-mill 68-69 BBO intake have a "J", but in different places. The common intake is casting number 398662. The H/O intake is casting number 405233. Of course the H/O intake has the nipple for the PCV valve sticking up behind the t-stat crossover.
Old Dec 18, 2017 | 03:12 PM
72 Olds CS
Old Dec 18, 2017 | 03:18 PM
And THAT is the run-of-the-mill 68-69 intake, NOT the 1969 H/O intake. Note the lack of the PCV nipple. The nipple is located right where the "J" is in this photo, which is why the "J" is on the other side on the H/O intake.
Old Dec 18, 2017 | 03:21 PM
scrappie's Avatar
Thanks guys, just in need of a little education on that.
Old Dec 18, 2017 | 05:50 PM
72 Olds CS
thats the pic from the cl ad i assume scrappie is looking at for just $350 you can own that...ad states "sandblasted" ?...musta been some time ago ...
Old Dec 19, 2017 | 06:18 AM
A common 68-69 BBO intake isn't worth $350. A correct 1969 H/O intake is probably worth ten times that.
Old Dec 19, 2017 | 04:40 PM
classicmuscle442's Avatar
Have the 68-9 intake, the 398662 (D1 S) one with the J on pass. side of water inlet.
Old Dec 20, 2017 | 04:43 AM
timholliday's Avatar
Member
Here is an image of a '69 H/O intake.
Wildcard
Dec 26, 2012 07:48 AM
Nickyloves442s
Oct 24, 2012 04:55 PM
svnt442
Jul 17, 2011 04:43 PM
71cuttyS
Oct 31, 2007 04:58 PM
