Neutral safety switch
I believe the 1969 & 1970 had the switch on the floor shifter. The 1971-72 shifter looks the same but without the switch on it. If someone else doesn't come up with the answer first I'll try to get a picture of a 1969 shifter showing where the switch is attached. John
I converted my 70 column shift with a console and shifter from a 72. I just left the backdrive linkage connected to the column mounted nss switch. Works perfect. Why waste money on a rare part unless it's a concourse restoration.
I'm not sure if your wanting to have your car original or not. If not, it might be easier to do what 4speed455 suggested. Either way, here's a couple photos of my 1969 with the factory floor shifter. Let me know if you have any questions or would like to see any other views. John
Charly9g
November 6th, 2016 06:10 PM
oldspackrat
November 17th, 2014 07:31 AM
