74 Cutlass Supreme Buckets
Old October 19th, 2017, 04:34 PM
sammieolds's Avatar
Hi I知 looking to get a set of buckets Black is there a list or a knowledgeable web site for that
I知 sure a lot of a body痴 would fit
Any help Appreciated
Steve
sammieolds is offline
Old October 19th, 2017, 04:40 PM
Paladin31's Avatar
I have a few sets, they aren't specifically from a 74, but all standard buckets fit 73-77 GM A bodies that had standard buckets already, if your car had & are replacing swivel for swivel buckets its a even swap. However the mounting locations are slightly different for swivel than standard buckets and the seat belts are totally different.
Brett
Paladin31 is offline
Old October 19th, 2017, 05:28 PM
sammieolds's Avatar
I have a split bench
New upholstery
New upholstery
Old October 19th, 2017, 06:36 PM
Paladin31's Avatar
#1 NICE car, I like that color. The bench seat uses same outboard mounts as a standard bucket, you would need to add the inner mounts & then get seats. Also need the long seat belts & stalks for the inner female sockets, good luck on OEM they shatter like glass when old. I have heard that you can modify stalks manufactured for modern cars, just don't have the web addresses to share. Hope this helps
Brett
Brett
Old October 19th, 2017, 06:38 PM
texxas's Avatar
1973-77 Strato bucket seats use the same out board mounting points as the bench seat mounts and use the same seat belts as the bench(rear leg mounts on retractor housing), just delete the middle set of belts. I do not know if the inboard mounts for your 60/40 seats can be used for buckets. And as long as you're swapping to buckets MAW get a console and floor shift too.
texxas is offline
Old October 20th, 2017, 03:59 AM
sammieolds's Avatar
Thanks Guys you’re right Brett the coat hooks came off in my hand I tryed to hang a small wireless speaker on it
Old October 20th, 2017, 05:12 PM
Paladin31's Avatar
Seats & sundries
Since Texxas mentioned it....I have a couple pieces here and there let me know if I can help
Brett
Old October 21st, 2017, 02:40 PM
sammieolds's Avatar
A couple lol when I do this I plan on building a small console and putting a radio in it keep the shift up top
I’ll keep this in mind if I change my mine
Steve
Old October 21st, 2017, 04:44 PM
Paladin31's Avatar
if your still using bucket seats then, perhaps a 73-77 console cut off at the coin tray area (sits just fore of the shifter slots) Thus it would still fit the floorpan contour, be easy to anchor, and you might use the 'garage door' compartment to secure the radio.
Just something to think aboiut
All the best,
Brett
Old October 21st, 2017, 05:17 PM
Hookers under Hood
76olds's Avatar
Hey Steve,
Just some ideas to pass along to you here.
A member on the new 73-77 oldsmobile forum took a 73-77 console cut it down to fit between his 60-40 bench.
It looks very nice, did a really good job!
Another member pulled his bench out, put a nice set of recovered buckets and console in, put some cup holders in place of the shifter.
It also looks really nice.
You should check it out.
Brett is our 73-77 parts, go to guy on here and the other Olds forum. He usually stocks a couple parts for us haha.
Most of our wives would kill us LOL, so we let Brett keep all the extra 73-77 parts stock at his house haha.
Your car look amazing Steve, nice interior!! Cut a console down it will look amazing!!
Cheers
Eric
76olds is offline
Old October 22nd, 2017, 03:14 AM
sammieolds's Avatar
Good info guys
Old October 24th, 2017, 05:21 AM
Platinum Al's Avatar
I am the guy Eric mentioned. Here's mine with bench seats and then I put buckets in. My cut console is for sale.
Platinum Al is offline
Old October 24th, 2017, 05:24 AM
Trans am buckets recovered in NOS material to match my rear seats.
Old October 24th, 2017, 09:23 AM
DrOldsMN's Avatar
Al where did you find NOS material? I want to do the same with my 76 Brougham black interior.
DrOldsMN is offline
Old October 24th, 2017, 10:31 AM
I bought it off of EBay. Company is Automotive Restoration Supply. Phone is 613 925-5863. Helga Keller is the owner. Hope she has want you need.
Old October 24th, 2017, 11:27 AM
DrOldsMN's Avatar
Thanks, I'll give them a call.
DrOldsMN is offline
Bosshoff
May 20th, 2016 07:00 AM
Prophe'c
October 20th, 2014 03:38 PM
oldspackrat
October 24th, 2013 06:50 AM
deflepnut2003
September 9th, 2012 03:11 PM
geowindow6768
August 1st, 2008 08:03 PM
Quick Reply: 74 Cutlass Supreme Buckets
