rocker stands?
Old Apr 11, 2012 | 06:38 PM
charlierogers's Avatar
rocker stands?
ok guys, putting my 70 455 back together {stock build} and waiting for heads to come back from machine shop. i had a friend who was a olds freak back in the 80s-90s and remember helping him put a couple motors together and i thought we changed the stock aluminum rocker stands {i think thats what there called?} out for steel ones because the aluminum ones broke. what do you guys say?
charlie,,,
Old Apr 11, 2012 | 06:55 PM
Oldsmaniac's Avatar
I am not familiar with stock steel style stands or bridges. The rockers were iron/steel but the bridges are a babbit or aluminum.
Old Apr 11, 2012 | 07:26 PM
copper128's Avatar
Lt. Buzzkill (ret.)
Crane used to sell the "improved style" 3-piece steel rocker pivots & bridges to replace the factory 1-piece cast aluminum parts.
I think maybe Sealed Power still makes them.
Old Apr 11, 2012 | 08:07 PM
70Wcars's Avatar
There is a better Pivot/Bridge available. Elgin and as said maybe Sealed Power. It's two seperate Pivots and a steel bridge..stronger and the pivots are Oil Grooved and the steel Bridge will not break like the stock cast Bridge.
Just a reminder to check the Lifter Pre-load when you re-assemble...shims are available if it is too deep, or you can sand or file a bit off the base of the pivot if you need to add more. Not preaching, but I see this neglected often.
Danny
Old Apr 12, 2012 | 05:19 AM
Danny[/QUOTE]
sounds like a lot of extra work. maybe i will just modify it buy dropping a sbc in it instead. i dont see this as preaching but good info that i and others can use. thanks for the tips!!!
charlie,,
Old Apr 12, 2012 | 08:31 AM
Run to Rund's Avatar
I have used the aftermarket stands on a set of rockers marketed by Crane several years ago. They work, but when tightening the bolts you have to be very careful that the pivots don't turn a bit and bend the stamped steel bridges, letting the rocker get cocked sideways. I have had no trouble with the stock aluminum stands so long as one side isn't tightened all the way first, and the side with some tension on it because a lifter is partway up a lobe is tightened some first so there isn't tension on the pivot trying to break it.
442rocketdave
Jun 9, 2013 02:37 PM
crazy'boutOlds
Sep 3, 2011 08:15 AM
Axeni
Nov 28, 2010 09:19 AM
rtpassini
Mar 3, 2010 06:23 PM
Flye
Aug 23, 2009 06:50 AM
