rocker stands?
rocker stands?
ok guys, putting my 70 455 back together {stock build} and waiting for heads to come back from machine shop. i had a friend who was a olds freak back in the 80s-90s and remember helping him put a couple motors together and i thought we changed the stock aluminum rocker stands {i think thats what there called?} out for steel ones because the aluminum ones broke. what do you guys say?
charlie,,,
charlie,,,
There is a better Pivot/Bridge available. Elgin and as said maybe Sealed Power. It's two seperate Pivots and a steel bridge..stronger and the pivots are Oil Grooved and the steel Bridge will not break like the stock cast Bridge.
Just a reminder to check the Lifter Pre-load when you re-assemble...shims are available if it is too deep, or you can sand or file a bit off the base of the pivot if you need to add more. Not preaching, but I see this neglected often.
Danny
Danny
Danny[/QUOTE]
sounds like a lot of extra work. maybe i will just modify it buy dropping a sbc in it instead
. i dont see this as preaching but good info that i and others can use. thanks for the tips!!!
charlie,,
Danny[/QUOTE]
. i dont see this as preaching but good info that i and others can use. thanks for the tips!!!charlie,,
I have used the aftermarket stands on a set of rockers marketed by Crane several years ago. They work, but when tightening the bolts you have to be very careful that the pivots don't turn a bit and bend the stamped steel bridges, letting the rocker get cocked sideways. I have had no trouble with the stock aluminum stands so long as one side isn't tightened all the way first, and the side with some tension on it because a lifter is partway up a lobe is tightened some first so there isn't tension on the pivot trying to break it.
