Stock Appearing
Old Sep 24, 2023 | 03:53 PM
dc2x4drvr's Avatar
Stock Appearing
Saw this on V8Buick, 11.50 with a 400,C heads, cast iron manifolds, wicked launch..
https://www.v8buick.com/index.php?th...g-olds.388698/
Old Sep 24, 2023 | 05:56 PM
83hurstguy's Avatar
Neat build and car. Some original bias ply tires would take care of that twist problem.
Old Sep 24, 2023 | 06:00 PM
11.50 with no second gear? Holy cow.
Old Sep 24, 2023 | 08:01 PM
I’m trying to understand exactly how that short shift happened. Doesn’t make sense with the information presented.
Old Sep 24, 2023 | 08:22 PM
Bernhard's Avatar
Cool build.
Would like to hear more about the build.
Old Sep 25, 2023 | 04:42 AM
fleming442's Avatar
Exactly. 1st & 3rd are in the same plane.
Old Sep 25, 2023 | 04:50 AM
New2oldsw30's Avatar
I have a BBc that "could" run this stuff. It was built with F.A.S.T. "STOCK APPEARING" in mind, but has headers. I spoke to a bunch of those who run that and got some tips, plus with the experience of friends running NHRA and MMPS Pro Stock classes, we did pretty good I think.FYI, mine is a 1969 ZL1 that will find it's way into a '69 Vette. Plan is to try and run 8.999 or better with pretty much the stock appearing rules but use headers and slicks.
Now not knowing much about Olds engines, I see this thing being stroke to the max, ported to the max heads, intake and ex manifolds. ONLY difference is the cost to do the engine goes WAY up as manifolds are usually in the $3000/$3500 range. I have seen a few on here that run in the high 10's with some nice parts, not maxed out and even flat tappet cams.
It's really not that hard to get these to run low 11's like that, just a lot of $$$$. For example, look at Stock Eliminator. Not take that ADD cubic inches,proller cams and porting to the max. An HONEST 600Hp will get you there.
Old Sep 25, 2023 | 09:51 AM
Bernhard's Avatar
Bernhard wrote:
What makes this stock appearing build impressive is that its the bore restricted 400 G block. { If the information provided is correct? } Some have claimed to have gone .125 over on the G block giving it a 4" bore.
I would like to know more about the build as it is highly unconventional .
Old Sep 25, 2023 | 02:26 PM
CANADIANOLDS's Avatar
Post pics and vids of the car… have to be a member otherwise
Old Sep 25, 2023 | 04:03 PM
they can go +.140” if it’s good on the core shift. With a 4.5 stroke you’re talking 455.
11.5 is a full second slower than the quickest F.A.S.T. Small block car. They have work to do
Old Sep 25, 2023 | 05:27 PM
Bernhard's Avatar
Old Sep 25, 2023 | 05:47 PM
Bernhard's Avatar
Bernhard wrote:
It will be interesting to see the progression of the car.
117 mph so there should be more in it.
Old Sep 25, 2023 | 06:24 PM
and the max compression you can stuff into it..minimum 15.5 or you leave power on the table
high first gear in the trans and not much rear gear to prevent breaking the tires loose off the line..you want to kill the TQ down low . power has to come on slow like a turbo car way after the 60’ and be pulling like a freight train by the 330” .
soft 1 to 2 shift and a harder 2 to 3 so it doesnt break the tires loose…more like a stock shifting tranny
Old Sep 25, 2023 | 09:22 PM
Bernhard's Avatar
Bernhard wrote:
Could you archive 15.5 compression ratio with that bore stroke ratio?
Old Sep 26, 2023 | 09:44 AM
Soft 1 to 2 shift and a harder 2 to 3 so it doesn't break the tires loose…more like a stock shifting tranny
Is that what causes it to skip 2nd altogether?
Old Sep 26, 2023 | 01:09 PM
of course.
Old Sep 26, 2023 | 01:10 PM
no. They must have had other issues. The article is pretty vague on everything
Old Sep 26, 2023 | 06:53 PM
Bernhard's Avatar
The post says that the car twisted so bad that it caused issues with the column shift, resulting in a miss shift 1 to 2, going straight to 3 that resulted in a large rpm drop.
Old Sep 27, 2023 | 02:11 PM
it’s story time🤣🤣🤣
was it build to compete in F.A.S.T.?
Old Sep 27, 2023 | 06:57 PM
Bernhard's Avatar
it’s story time🤣🤣🤣
Bernhard wrote:
If it was floor shift car 100%. Column shift car with the rod connected to the steering column and bolted to the firewall maybe?
Information on the car and build is very limited and it was the first time out for the car. It's an unconventional build if it was built for F.A.S.T
When I think of F.A.S.T Oldsmobile build.
Going to have to mill an oil filler tube hole in the block.
Dale have you ever thought about doing a F.A.S.T build?
Old Sep 29, 2023 | 02:07 AM
yes..it’s past the thought stage. Been doing it off and on for a while but other builds keep slowing me down..I’ve got the body which will be a 69 H/O clone and will be able to switch back and forth from the big block class to small block 69 W31
it’s costly because it will be competitive. Stock block for each build. Big Block has billet caps&girdle , it will get this Moldex billet 4.850” crank, with a 4.200” bore for 538”. GRP al rods. Big comp 800” sr, offset cup crower lifters. Lots of welding on the D heads. The cast iron intake has been cut down in weight from 80 to about 40lbs…can’t show pics of that until it’s finished 😉 and closed back up.
Old Sep 29, 2023 | 03:23 AM
fleming442's Avatar
Savage.
Old Sep 29, 2023 | 04:51 AM
66_Jetstar's Avatar
The builder posted the car was untouched with stock suspension and is only 9.2:1 compression, factory heads and manifolds.
I am beginning to doubt this is actually a real combo without some massive power adder.
Old Sep 29, 2023 | 07:07 AM
Bernhard's Avatar
Nice max effort F.A.S.T build!
What transmission are you going to run?
Old Sep 29, 2023 | 09:29 AM
400T with a higher 1st
Old Sep 29, 2023 | 10:18 AM
Old Sep 29, 2023 | 06:53 PM
Bernhard's Avatar
I assume the offset lifters allowed you to move the push-rod location in the heads to maximize cylinder head flow? Are the lifters custom or were you able to use an existing lifter?
Old Sep 29, 2023 | 07:01 PM
Bernhard's Avatar
Dale.
I know quite a few stock guys are running the metric 200 or the turbo 350, what was the reason you chose go with the turbo 400?
Old Sep 29, 2023 | 09:10 PM
Yes on the reason..custom .180” offset high cup location
Old Sep 29, 2023 | 09:17 PM
Dale.
I have no idea if either of those trans would handle the TQ I plan on making without costing a fortune?
Send my any info you have on them behind a big TQ big block and I’ll read up on them
Old Sep 30, 2023 | 10:06 AM
  #31
Bernhard's Avatar
Bernhard wrote:
There are a few popular builders and many have spares in the trailer. I know they are expensive and reliability is ... . I have not seen a tech article on how to build one to live behind a stock or super stock car.
I agree the 400 is the most capable to handle the TQ of a Dale big block Oldsmobile coupled with the weight of a GM A body.
When cars had to run the transmission that the car was manufacture with in stock and super stock. They ran lightened factory parts to reduce rotating mass inside the transmission. I don't know what is available today for the turbo 400, as far as light weight internal parts
Old Sep 30, 2023 | 11:28 AM
  #32
Bernhard's Avatar
I just did a quick search on light weight turbo 400 transmissions and parts. The amount of parts available is only matched by the cost.
http://www.coanracing.com/catalog/ca...400-r2/id/213/
Old Oct 2, 2023 | 11:39 AM
  #33
83hurstguy's Avatar
Parts are looking good, Dale. Hopefully you can find the time to get that together some day.
davebw31
Sep 25, 2023 12:03 PM
deaddds
Jul 8, 2018 08:37 AM
Bowtie-Bri
Feb 12, 2018 03:15 PM
cutlassefi
Nov 12, 2013 09:51 AM
sethj78
Sep 23, 2011 01:28 PM
