FI tech fuel injection
Old August 7th, 2018, 05:39 PM
crank shaft's Avatar
Is anyone running a FI tech throttle body? I can't seem to get the timing correct. We put this on a 350 Olds and followed the directions but there very vegue. My base is at 10 degrees and my full advance is at 34 degrees. We set the cruising at 18 degrees. Can anyone please tell me where and how to set the timing. This thing is driving me nuts....lol
Thank you,
Mike
crank shaft is offline
Old August 7th, 2018, 11:16 PM
Gary M's Avatar
Following for future reference. Good luck. Have you called tech support at FiTech?
Gary M is offline
Old August 8th, 2018, 02:43 AM
Not yet. I figured I would post here first.
Old August 8th, 2018, 11:28 AM
cutlassefi's Avatar
With all due respect, I'm curious as to why you wouldn't contact the guys that do it all day every day first.
cutlassefi is offline
Old August 8th, 2018, 01:24 PM
I will. I have always received good advice from this site and just wanted to see if anyone has played around with this on a Olds engine. Sorry to bother you. I'll call the factory
Old August 8th, 2018, 02:40 PM
tmaleck's Avatar
I'm running the FiTech, but not using the timing control. I have a Mallory Unilite distr. I looked at using the timing control, but the cost of a dual sync distributor was more than I felt it was worth.
In this situation you may need to bring in your advance sooner, 18 degrees seems low depending on what cruise is. The problem is there are only 8 table entries for timing. The system interpolates 'guesses' what the advance should be in between those entries. I'd have to check my handheld control to see how to edit the table entries.
FITech knows their product, I talked with them a few times with good results. They don't know how to best set it up for an Olds motor though.
tmaleck is offline
Old August 8th, 2018, 04:17 PM
cutlassefi's Avatar
You don’t need a dual sync, just a locked out dist that’s phased correctly. Dual syncs are really for mpi running in sequential. But you’re short changing yourself big time by not having timing control.
And again it doesn’t matter what brand engine it is, just whether or not you have an ignition system that’ll work with their setup.
Old August 8th, 2018, 05:16 PM
Thank you. We set our base timing to 10 degrees. I figured that was a good starting line. On the low end it's ok but I think it could use more from cruiseng on up. I will call the factory this week .
Thanks guys!
Mike
Last edited by crank shaft; August 8th, 2018 at 05:18 PM. Reason: Mis spelled word
HLS
December 27th, 2016 04:26 PM
DoubleV
February 22nd, 2015 08:25 AM
boese1978
April 1st, 2013 12:21 PM
67Olds442X2
September 18th, 2011 01:39 PM
coltsneckbob
November 25th, 2010 06:22 AM
Quick Reply: FI tech fuel injection
