What do you run for an ignition system?
Old May 16, 2022 | 03:58 PM
  #41
therobski's Avatar
Still use points works great!~( just having fun with some of you non-dark siders )
Old May 16, 2022 | 05:00 PM
  #42
bccan's Avatar
No need for arguing! I mean, it’s not oil or cylinder heads! Post what you run or prefer, let the preceding and next people have their say & preference as things have mostly proceeded.
I gave up on points as they were regularly needing adjustment to suit my **** retentiveness, not because they don’t work. Wouldn’t for a second poo poo points, they have worked reliably for a century+. Early 80’s I had a high speed miss in my 65 442 that an Accel dual point solved.
I like HEI’s, despite working through the curve issues on GM units while absolutely loving the adjustability of my Mallory 75 series “HEI,” an uncommon choice, as long as I don’t need to adjust the curve while it’s in the car as the configuration doesn’t even resemble GM. Happily, in 15 years I have never had to adjust it but have had a module (Mallory) and a pickup (Ford EEC-x) commit suicide.
I have had a GM pole piece fail and had to do a roadside distributor change twice, maybe 3 times counting the GM, can’t remember over the 20+ years on the road . I always carried a set of emergency points but don’t remember ever using them, I keep an HEI in the trunk and have had to use it until post mortem could be performed. I have seen 2 sides to Pertronix conversions, seen a number of them fail while there are a lot of people happy with them. I don’t understand various ignition boxes but they are widely in use by a lot of people with seeming success. Maybe I’m missing out on something but have never felt the need to explore. I can’t even fathom mag triggers, multi coil setups, etc. they obviously have benefits as the “bigger boys” use them, but with my under cammed engine breathing through a straw, I need reliable spark through 5600 rpm, MAX, a few times, every few years, most Olds guys don’t even need it that high.
Oh well, to each his own, but I don’t think anyone is wrong in their choices, there are a lot of ways to ensure a spark in the right hole, at the right time.
Old May 16, 2022 | 05:15 PM
  #43
fleming442's Avatar
I've always heard the horror stories about MSD. I never had a problem with the 6AL, but I upgraded to the 2. I did have a pickup fail, and it rode the rollback.
James71Cutlass
Feb 9, 2022 09:52 PM
MD_Gould
Jun 14, 2015 08:55 PM
Tim305
Jun 13, 2014 05:08 PM
Oldsmofjord
Jul 26, 2007 01:21 AM
Chuck C
Apr 29, 2004 02:12 PM
