"Week Three" New PBT ET and 60' Time
Old Nov 13, 2012 | 07:54 AM
davebw31's Avatar
Ok, went to Panama City Dragway this past Sunday. Made no changes since "Week Two". Results as follows:
1st run: new PB 7:02 ET @ 97 mph with 1.56 60' time, YES.
Temp. 75* with 10-15 mph slight headwind. Have installed tubes in rear tires, air @ 10 psi.
2nd run: 7:08 ET @ 96.87 mph with 1:57 60' time.
Traction not as good
3rd run: 7:10 ET @ 96.76 mph with 1:57 6' time.
4th run: 7:12 ET @ 96. 56 mph with 1:58 60' time.
5th run: no ET but 60' time was 1:57. Got in to something, spun the tires and car got out of shape @ the 330' cone and had to back out of it big time!
Going to change the flat steel hood over to our light weight, lift off, W25 style hood for weight savings and getting some cooler ram air to the carb. Then will start jetting changes and timing. Hope to pick up a tenth or more! Past experience tells me it should pick up more than a tenth. Also, building up one of my spare Moser 12 bolt Ch**y rears to a 4:56 ratio to try that over the 4:10 ratio that is in the car now, for 1/8 tracks. I can see high 6's in the future!!!!!!!!!!!!!!
Old Nov 13, 2012 | 08:12 AM
jims2000lt's Avatar
11.52 @116
Congrats man!
Old Nov 13, 2012 | 08:20 AM
380 Racer's Avatar
Dave.......a 7.02 x 1.595 = an 11.197 quarter mile ET. Not too shabby . Both the hood and the 4.56s will help a bunch. You are doing very good!
Old Nov 13, 2012 | 08:41 AM
davebw31's Avatar
Thanks guys
380 Racer:
To be correct I did a "1.565 60' time" on my 7:02 ET pass. So 7:02 X 1.565 = 10:98 ET in the 1/4! Oh Wow!
BTW: still ony shifting on a 5700 rpm chip and going though the traps (last mph light) @ 5,400 rpm!
Old Nov 13, 2012 | 09:21 AM
380 Racer's Avatar
Hmmmm if you take your 1/8 mile ET times 1.595 you come up with what the 1/4 mile ET will be (approximately). My car sixtys 1.30 and ETs 1/8 mile 6.25 but runs the 1/4 about 9.96. Should have explained what I was doing better......Sorry.
Old Nov 13, 2012 | 09:42 AM
davebw31's Avatar
380 Racer:
It is all ok! So Andy, I am using the wrong 60' number for multipling X s my 1/8 mile ET???? Me confused. I thought (my problem, lol) the formula was 1/8 mile ET X 60' time = approx. 1/4 ET.
Old Nov 13, 2012 | 10:39 AM
380 Racer's Avatar
Dave, don't use the 60' time at all. Your 7.02x1.595=11.1969
My 6.25X1.595=9.96875
All the 1.595 is is a multiplyer or a divider if going the other way.
Clear as mud?
Old Nov 13, 2012 | 06:45 PM
davebw31's Avatar
380 Racer:
Yes , yes clear as mud. Ok I got it, it is the multiplyer of 1.595 that I need to use when figuring 1/4 times! Thanks bro.
Old Nov 13, 2012 | 07:14 PM
70Wcars's Avatar
Dave: Congrats!! That car is moving and has lots more in it by the sound of things.
My 9.76 pass was a 6.15 in the 1/8 mile...so 1.59 worked as multiplier. There may be a slight variance in times when using conversion equations..cars may lay-down on the top end, or pull harder...
Just my experience..
Danny
truerollers
Feb 28, 2017 01:00 PM
F-85 4-4-2
Apr 7, 2014 09:44 AM
davebw31
Oct 30, 2012 12:35 AM
jaunty75
Aug 20, 2010 03:24 PM
