Next Stroker
Old April 22nd, 2021, 02:46 PM
cutlassefi's Avatar
Next Stroker
EFI’d 428ci
4.125” Mahle piston
4.00” Stroker crank
Eagle I beams
Lunati Hyd roller 238/242@.050 112lsa
Decent Procomp/Speedmasters
Comp cams 1632-16 rockers
RPM intake bunged for port injection
Wilson manifolds 1300cfm throttle body
Holley dual sync dist
Coil on plug
AEM Infinity 508 ECU
Made 480ish on a carb, we’ll see what it does with EFI on both pump gas and E85. This is a flex fuel build.
cutlassefi is offline
Old April 25th, 2021, 03:35 PM
Mr Nick's Avatar
Sequential or batch fire?
Is there a noticeable difference in performance & drivability between the two?
When using sequential, can injector firing be "timed" similar to changing ignition timing.
Mr Nick is offline
Old April 25th, 2021, 05:03 PM
cutlassefi's Avatar
All good questions Nick.
Sequential, yes you can change when they fire.
Usually not much difference in power between the two modes but dtivesbility is normally better in sequential mode, especially with larger cams.
And one of the reasons I really like the AEM Infinity is that you can run two Widebands that can be configured to treat a V8 like two four cyl engines, controlling each bank of injectors independently of each other. Cool stuff.
Old April 25th, 2021, 08:48 PM
Oldcoyote's Avatar
Coil on plug! Just like the new ones?
Oldcoyote is offline
Old April 26th, 2021, 04:35 AM
cutlassefi's Avatar
Yes.
Old April 26th, 2021, 09:40 AM
bccan's Avatar
Go, Dog. Go! (ooops! Is that racist, evil and politically incorrect?!?)
Love watching your builds. Keep em coming.
bccan is offline
Old April 26th, 2021, 04:40 PM
ELY442's Avatar
Did you use the same carb on the 434 stroker? What injectors are you using?
ELY442 is offline
Old April 26th, 2021, 05:44 PM
cutlassefi's Avatar
Yes.
FAST 65# EV6 LS Style.
Old April 26th, 2021, 05:47 PM
cutlassefi's Avatar
Originally Posted by bccan
Go, Dog. Go! (ooops! Is that racist, evil and politically incorrect?!?) LOL
Thank you! Working on another project, the epitome of cool (in my opinion). Hope to have a running application by years end.
Old April 26th, 2021, 08:58 PM
Out of Line, Everytime😉
olds 307 and 403's Avatar
Sounds very interesting!
olds 307 and 403 is offline
Old April 27th, 2021, 02:50 PM
ELY442's Avatar
I guess its not electric. What are your thoughts about a high performance electric motor?
ELY442 is offline
Old April 27th, 2021, 03:06 PM
wr1970's Avatar
Cool glad you are showing these builds. Congrats Mark.
wr1970 is offline
Old April 27th, 2021, 03:42 PM
HighwayStar 442's Avatar
Not sure what this will be. But it has the back two mains of a 403 Old's.
HighwayStar 442 is offline
Old April 27th, 2021, 03:46 PM
Mark, Hope its a d or dx with new BBO Edelbrock heads
Old April 27th, 2021, 04:40 PM
cutlassefi's Avatar
It’ll have the new Edelbrocks on it but I’m not going to say anymore, other than it’s not electric.
Old May 2nd, 2021, 05:49 AM
DROLDS707172's Avatar
Stroker
Bet it makes 500ish on e-85
DROLDS707172 is offline
Old May 26th, 2021, 08:46 PM
olds403's Avatar
Mark,
Send it…..let the cat out.
You don’t need to hide anything now.
olds403 is offline
Old May 27th, 2021, 04:06 AM
cutlassefi's Avatar
Originally Posted by olds403
Mark,
Ok, here you go.
First pull, 33* of timing, 93 pump. Probably a little more in it as it’s a bit lean but we’ll be moving over to E85 very soon.
Old May 27th, 2021, 04:25 AM
Torque numbers are steady and high! Give details, Please.
Old May 27th, 2021, 06:18 AM
cutlassefi's Avatar
Most of the build details were already given but just to add it’s just over 10.0:1 with 2.07/1.68 valves I believe(we pulled them from another set of heads). Flow was mid 250’s at .600, cam lift is .587 I think.
Other than that everything else is listed.
Old May 27th, 2021, 07:03 AM
VORTECPRO's Avatar
Every thing is listed? How about the the:
1. BSFC
2. Fuel flow
3. VE
4. Correction factor
5. Barometer
6. BMEP
It would be nice to see how you arrive at the numbers
VORTECPRO is offline
Old May 27th, 2021, 07:13 AM
cutlassefi's Avatar
Air mass/sec, VE and fuel flow are calculated thru the ECU. The real target here is pump gas vs E85. ECU will tell me that as well.
Old May 27th, 2021, 07:14 AM
ctosiflying's Avatar
Good God! Here we go again!!!
ctosiflying is offline
Old May 27th, 2021, 07:15 AM
Sweet build Mark!
Old May 27th, 2021, 07:22 AM
cutlassefi's Avatar
Originally Posted by ctosiflying
Sweet build Mark!
Thank you. Again the real focus is pump vs E85. The cam favors that as well.
Old May 27th, 2021, 07:27 AM
olds403's Avatar
Correct Mark. The valves / springs came from a set of edelbrock heads we did at champion racing that I shipped from another motor.
Those parts went into the bare pro-comps that were built around this motor. Those edelbrock heads now are collecting dust. 😜
olds403 is offline
Old July 14th, 2022, 08:44 AM
Bernhard's Avatar
https://www.motortrend.com/how-to/09...mobile-engine/
Bernhard is offline
Old July 14th, 2022, 10:30 AM
cutlassefi's Avatar
I’m well aware of that build, I get your point. I know you don’t think much of me anyway so……
And posting that on this particular thread was a pretty tacky thing to do by the way, no relevance, apples and oranges.
Old July 14th, 2022, 11:46 AM
Bernhard's Avatar
To be honest it was a miss post in the wrong area, so I sincerely apologize. This thread was under the thread I wanted to post in as in similar threads.
As far as not thinking much of you, you are dead wrong !!! I think you have done more than some self proclaimed Olds experts.You are responsible for helping to bring many new performance products to the Oldsmobile community and have a loyal customer base that is happy with there performance engine builds. One of your customers lives not to far from me so you are creating a large customer base, good on you!
I'm even trying to encourage a good friend to go with your small block stroker packages because I think its a cool build with lots of up side.
The problem with the internet or email is that its hard to read intent in to what the person is saying. I not trying to be a douche.
Bernhard is offline
cutlassefi
April 25th, 2021 10:50 AM
exotec
Non-Olds Engines
November 27th, 2019 02:21 AM
cutlassefi
October 21st, 2017 02:59 PM
cutlassefi
January 11th, 2017 05:54 PM
cutlassefi
April 18th, 2013 05:27 AM
Quick Reply: Next Stroker
