New Edelbrock Heads
Old Sep 19, 2021 | 10:26 AM
  #641
cutlassefi's Avatar
I wouldn't worry about the negative Nancy's. If truth be told most of them wouldn't/couldn't buy a set if they were in front of them priced half off.
Oh I know. But it still sucks that people think like that.
Another day at the dyno with the new heads on my 357ci mule. These are good right out of the box😎.
Old Sep 19, 2021 | 11:57 AM
  #642
tru-blue 442's Avatar
Old School Olds
Old Sep 21, 2021 | 02:46 PM
  #643
cutlassefi's Avatar
More testing today on the small block heads.
What if I were to tell you that 450hp+ on 91 pump gas would be very doable and streetable with a 350 and off the shelf pieces?
Old Sep 21, 2021 | 02:59 PM
  #644
NTXOlds's Avatar
What if I were to tell you that 450hp on 91 pump gas would be very doable with a 350 and off the shelf pieces?
You have my attention.
Old Sep 21, 2021 | 03:01 PM
  #645
HighwayStar 442's Avatar
Torque?
  #646
cutlassefi's Avatar
Not done yet but this head will be a bonafide game changer for even the average small block guy. Torque would be 425+ at the very least.
Old Sep 21, 2021 | 03:08 PM
  #647
cutlassefi's Avatar
Sure is purdy ain’t it?😎
Old Sep 21, 2021 | 04:33 PM
  #648
deadeyejedi's Avatar
This is one of the things I’m interested in , bolt them on and go! The previous edelbrocks seem to need a bunch of work to make them better . I don’t mind spending the money on the heads but would rather not buy a set and then put a grand into them .one of the reasons I’ve stuck with the irons , maybe these will change my mind.
Old Sep 21, 2021 | 05:18 PM
  #649
chadman's Avatar
I'm far more interested in seeing how much a fully competition ported set can make on a 500+ CID 15:1 solid roller BB.
Old Sep 21, 2021 | 05:20 PM
  #650
cutlassefi's Avatar
Grab a set when available and have at it😉!
Old Sep 21, 2021 | 05:24 PM
  #651
cutlassefi's Avatar
Don’t believe everything you hear. I’ve done a bunch of builds with out of the box Edelbrocks and made competitive power.
This new small block head will be a welcome addition, guaranteed.
Old Sep 21, 2021 | 05:27 PM
  #652
chadman's Avatar
If it gets proven that they can make more power than any of the three sets of fully ported aluminum heads I already have you can bet your lunch I will.
Old Sep 21, 2021 | 05:30 PM
  #653
chadman's Avatar
Mark, on the big block heads, you mentioned that there was more material above the port roof for raising the intake runners. Did they also go to a longer valve and add material to the spring seat area so the bowl can be made deeper?
Old Sep 21, 2021 | 05:31 PM
  #654
66-3X2 442's Avatar
Be careful telling numbers,some of the Nancy's will say different. LOLOLOLOLOLOLOLOLOLOL
Old Sep 21, 2021 | 05:49 PM
  #655
cutlassefi's Avatar
I said “doable”, not guaranteed.😉
Old Sep 21, 2021 | 05:51 PM
  #656
cutlassefi's Avatar
Both heads have more material everywhere except where they scalloped the end. Valve length is the same as before but machining the seats a bit shouldn’t be a problem.
Old Sep 21, 2021 | 09:25 PM
  #657
bigrbandit's Avatar
72 Cutlass Ponca City OK
Mark
They look like very nice heads, I can wait till next year and then I am sure you will have excellent cam suggestions and they will be available at Summit.
Old Sep 22, 2021 | 04:50 AM
  #658
VORTECPRO's Avatar
Thats great, your making as much HP as my pump gas production GM headed 327 utilizing a flat tappet lifter with a whole .480 lift, dual plane intake, with a 5/64 ring pack nice work!
Old Sep 22, 2021 | 04:59 AM
  #659
VORTECPRO's Avatar
When they become available I will take a look at them, Ck the guides for clearance, and ck the runout on the seats along with valve run out and make a video. Hopefully they will be better than previous Edelbrock efforts.
Old Sep 22, 2021 | 05:18 AM
  #660
olds 307 and 403's Avatar
Out of Line, Everytime😉
I am curious how much timing the new chamber likes vs the last gen or iron heads. Ah the peanut gallery.
Old Sep 22, 2021 | 05:49 AM
  #661
cutlassefi's Avatar
Yep, everyone here wants to hear about all your Chevrolet builds. Thanks!
Old Sep 22, 2021 | 05:59 AM
  #662
cutlassefi's Avatar
and make a video.
Wow!!!! I’m on the edge of my seat! Starring you? I can’t wait!!!!!
Old Sep 22, 2021 | 08:18 AM
  #663
fleming442's Avatar
I'm a fan of the Engine Masters series. I love seeing some of the old horsepower myths put to pasture. The one on aluminum vs iron heads will show you that the only differences are weight and ease of machining. Timing vs octane? No difference other than detonation resistance (important for power adders). Ice bags on the intake between runs? Nope, but old school cool can for the fuel? Yes. Most recently, oil pumps: not much difference. The high-zoot billet pump killed a few hp, but it was doing 80psi. Loosen the clearances, and that comes back.
So, yeah these new small block heads are great, but the comparison will be against a 1st gen big block head modified to fit or worked irons, not exactly apples to apples.
Either way, they need to stop teasing with unrealistic ship dates that they know won't happen.
Old Sep 22, 2021 | 09:26 AM
  #664
NTXOlds's Avatar
@fleming442 I agree that Engine Masters does a nice job of focusing on single variables when they test various changes to engines to assess performance differences, and you are correct that they showed that virtually identical iron heads and aluminum heads showed no real difference in HP, timing, etc. As you say, eventually we will have more definitive numbers on how these new heads perform versus stock iron heads, reworked iron heads and the Gen 1 aluminum heads. I look forward to the results when Mark or others have the time to perform these tests.
@VORTECPRO While your message may have been sarcastic, I think that you are highlighting the EXACT reason that these new small block heads are a big deal for us small block owners. It is nice to see Edelbrock making more performance parts for Oldsmobile engines, and it will be great to have access to bolt-on performance parts like the Chevy owners have, your 327 being a great example of what is possible with non-exotic, bolt-on parts.
As an owner of a 350 with #5 heads, my options are either to spend $2000+ on reworking my #5 heads for larger valves, new springs, porting and polishing, etc. or bolt on the new Edelbrock aluminum heads. Even if cost and performance were exactly equal, who wouldn't go with the lighter aluminum heads unless you are a stickler for originality?
Old Sep 22, 2021 | 09:58 AM
  #665
New small blocks heads are great. In my eyes the big block head has 2.15/1.68 valves and reworked chamber. Are the real winner. For me the max ported big block heads on bored out 350D or DX block. With the right parts. Would be bullet proof animal.
Old Sep 22, 2021 | 10:39 AM
  #666
cutlassefi's Avatar
Small block head has the same new chamber, just smaller valves and less cc.
And I’m a fan of the engine masters series as well, to a degree. Check out the build specs on their 351W mule. You’re going to make comparable power with these heads and a similar overall combination, no question.
Old Sep 22, 2021 | 05:32 PM
  #667
Duh's Avatar
Duh
Excellent question but, you need to re-read the question and think before you answer.
Old Sep 22, 2021 | 06:15 PM
  #668
cutlassefi's Avatar
What did I miss? He asked about material thickness, I answered it. He asked about valve length, I answered it. Lastly he asked about spring seat thickness in particular, I answered it.
Old Sep 22, 2021 | 07:05 PM
  #669
66-3X2 442's Avatar
I don't think I've ever seen someone take a beating like you have just for trying to help the hobby and bring a product to the masses.
Old Sep 22, 2021 | 07:09 PM
  #670
VORTECPRO's Avatar
My point is: A 350 Olds with its big bore and short stroke combined with a big valve aftermarket head has some very serious potential in my opinion. Olds 350 power from my shop would get all over my production headed small cammed 327.
Old Sep 22, 2021 | 07:42 PM
  #671
Duh's Avatar
Duh
WIth answer of , you can machine the seat , you missed the point of the question.
Old Sep 23, 2021 | 05:10 AM
  #672
cutlassefi's Avatar
Overall casting hasn’t been finalized yet. I should’ve said that first, sorry.
Old Sep 23, 2021 | 05:19 AM
  #673
cutlassefi's Avatar
The bore is only .057 bigger than a 302/327/350 Chevy. Stroke is .100 shorter.
I agree it has serious potential, I’ve already said that. Since you haven’t figured it out though, the overall combination of my mule isn’t necessarily an optimum combination for a real good street build with this head, much less something destined for the track. Again I’m well aware of that, Edelbrock is too. We’re working with what we have right now but other plans are already in the works. Plus there are other areas we are focusing on that are way over your head. Most of you have no clue what goes into this. I didn’t either before now. It’s a process for sure.
Note; for the Engine Masters crowd, watch season 5 episode 10, 351W Intake shootout. You’ll be right there with this new head.
Old Sep 23, 2021 | 05:52 AM
  #674
VORTECPRO's Avatar
IMO a good number from a street 350 Olds with a aftermarket head should be right around 500 HP, maybe 480 HP with a flat tappet cam @ 6400 RPM, that should be very doable.
Old Sep 23, 2021 | 06:01 AM
  #675
I personally think the mule has some nice parts in it, my bank account says so too. What are the specs on the Crane roller cam you are testing? Nothing wring with testing something that will have reasonable manners and still produces great power. Now these heads on a 425+ ci small block stroker should make block testing power on a regular gas 350.
Old Sep 23, 2021 | 07:24 AM
  #676
cutlassefi's Avatar
What are the specs on the Crane roller cam you are testing? Nothing wrong with testing something that will have reasonable manners and still produces great power. Now these heads on a 425+ ci small block stroker should make block testing power on a regular gas 350.
They’re Crane LS lobes on an 8620IG Core. Spec is 222/228@.050, on a 110lsa with .555 lift on both.
Velcro- I’ve asked before, and I’ll ask again since it seems you still haven’t figured this out. This is an Olds site, not a Chevy site so please don’t clump us in with that community. While I believe 480 or so will be very doable in street trim, we don’t have the plethora of off the shelf heads available to us like you do. We’ll have ONE true off the shelf, bolt on piece for a small block Olds. Let me repeat that, ONE. You have heads with different valve angles, styles, manufacturers, material etc. available to you. We’ll have ONE.
Old Sep 23, 2021 | 08:29 AM
  #677
skyhigh's Avatar
1972 Cutlass Town Sedan
I have a copy of show:
Season 5 Episode 63 Windsor Manifold Showdown
Old Sep 23, 2021 | 11:44 AM
  #678
skyhigh's Avatar
Thats pretty much the same spec cam you did for me, I would love to hear a pull Mark, little preview of the sound Jolene gonna have
Old Sep 23, 2021 | 11:47 AM
  #679
NTXOlds's Avatar
How much vacuum are you getting with that cam?
Old Sep 23, 2021 | 01:28 PM
  #680
cutlassefi's Avatar
About 15-16” at 850 or so depending on base timing etc..
