Metco driveshaft loop
I'm not familiar with the Metco drive shaft loop.
That being said, if you plan on taking the car to the track NHRA/IHRA have specific rules as to the placement. If I remember correctly it has to be within six inches of the forward u-joint and utilize grade 8 fasteners (bolts and washers) That's easy enough to look up online.
I'm replaceing my old lakewood piece of crap hopefully with something nicer. Metco or UMI Performance.
I had this one all cut up to fit but it worked for 13 years.
I know UMI Performance makes one like the Metco bu the Metco is around $10 less.
I had a Metco loop in my Ford Lightning along with some pulleys and they were great quality.
I have a Lakewood 18000 hanging on the wall here. I'm curious why you dislike it. Other than the bends being a bit crude, and the grade 6 bolts, It doesn't seem too bad. It looks like It could be attached directly to the crossmember If I Welded on some tabs for it to bolt up to.
Yuck. Doesn't sound like fun at all. I was curious, because I've never tried installing the Lakewood unit before. I just bought it because it was 15 bucks at a garage sale, and hung it on the wall.
I've thought of building my own but with work and my son on my days off I only get out in the garage once a week if I'm lucky.
Right now the trans, rearend, headers, exhaust, and interior our out of the car and I have a sidejob doing some body and paint work in about 2-3 weeks.
Around $72 dollars shipped from Jegs for the Metco loop sounds good to me.
I'ma member on there and remember seeing these months ago but forgot all about them. I'll be placing an order on monday. I really didnt want to drill more holes in my floor.
grade 6? if you mean 6 hash marks, those are grade 8.
I make my own out of bent pieces of 1/4" thick by 2" wide strap; it takes 3.5 to 4" of it to make one shaped to fit the floor inside, and one that clears the driveshaft underneath. I use four grade 8 bolts in 7/16 or 1/2" diameter. Especially if you upgrade your shaft to 4" for a higher critical speed, there is little room to the floor.
I run one of these...nice workmanship and reasonably priced. When you call you speak directly to the owner Steven Caruso on his cell. Very knowledgeable and helpful.
The piece comes powder coated, fits perfectly AND is made in the good Olds (sic) USA!
I recommend this company.
GOG
