Home Porting Techniques
Old Jan 23, 2026 | 10:59 AM
  #1081
67 Cutlass Freak's Avatar
Here you can see a good shot of the intake bowl before any blending. notice the harsh transition at the bottom af the cut.
Old Jan 23, 2026 | 11:04 AM
  #1082
Here you can see the initial grinding to smooth the valve job into the bowl. I am not trying to open up the bowl, or teardrop the guide, or do any major port work at all. I have been doing this long enough that I'm not really worried about nicking the seat. It soesn't take too long with a nice sharp carbide.
Old Jan 23, 2026 | 12:38 PM
  #1083
CANADIANOLDS's Avatar
Have you considered using thin wall bronze liners instead of stock iron replacement guides?
I use thin wall liners on everything..it’s much simpler , less work and you end up with a better guide that’s better for the valve stem.
It’s also a quick an easy way to use a smaller stem valve to reduce weight and increase flow, by putting a 5/16 or 8mm liner in the stock 11/32 guide for an 8mm valve.
either K-line or Rapid.
Old Jan 23, 2026 | 03:27 PM
  #1084
VORTECPRO's Avatar
Originally Posted by 67 Cutlass Freak
To address the practice of opening up the throat first, it's difficult to tell where the bottom angle of the valve job will be until you have performed the valve job. Especially if you're using oversized valves and opening up the throat. You can see from the pictures I have chosen a cutter that goes pretty far into the bowl. You can also see that the bowl is not concentric to the seat. This is very hard on the cutter. Basically there will be high spots and low spots as you are cutting. I used to do a secondary cut with a radius cutter, but that just takes more time.
Ok-let me educate you, as I've done Olds heads before myself.
On the first hole you run your valve job and leave it high .005, you then go in and cut the bowl where you want it, you then set the stop and cut the other 3 bowls out, you then you recut the first seat set height, then cut the rest of the seats, thats the best way to do it. While we're on this, rebuilder cast valve guides is not the best way to do this, CHE bronze guides honed to exact size is the best way to do the job. And on that Serdi you better have a perfect round, sized, strait guide and a perfectly sized pilot or you have a less than desirable seat.
Old Jan 23, 2026 | 03:31 PM
  #1085
VORTECPRO's Avatar
I use those too........
Old Jan 23, 2026 | 04:09 PM
  #1086
yep…I haven’t used an iron guide since the 90’s on anything.
the thin wall bronze liners also transfers heat better than iron , which is crucial for pulling heat out of the ex valve….that’s where the majority of heat transfer takes place
if anyone is using positive type seals with iron guides on the exhaust in a performance app, they’re taking a chance..unless they up the clearance by another . 001+
Old Jan 23, 2026 | 04:59 PM
  #1087
VORTECPRO's Avatar
Nobody serious uses cast guides, in my opinion. One piece CHE bronze guides are the gold standard period, but I also use Klines as well, but they are always honed to size.
Old Feb 22, 2026 | 05:33 PM
  #1088
coppercutlass's Avatar
Chevy budget Olds powered
Now this is random but .... What about the Goodson K liner kit where you size the liner with the ( check ball ) that's meant for the corresponding valve stem diamanter.
Old Feb 22, 2026 | 07:56 PM
  #1089
sizing ***** work fine, as long as the internal dimensions of the guide you’re putting the liner into is parallel. sizing ***** only size at the point of ball contact.
an iron guide can have a twist or bend in it , the ball will just follow that contour and in turn, push out the thin wall liner to that shape …as opposed to a hone which will insure the new liner is straight top to bottom.
so you just have to make sure the old iron guide is reamed straight and true to begin with
Old Mar 2, 2026 | 08:10 PM
  #1090
VORTECPRO's Avatar
Thats fine but it still must be honed to size to make it round and strait.
67 Cutlass Freak
Mar 24, 2016 08:42 PM
nukesec1
Nov 30, 2013 09:02 PM
DoubleV
Jun 20, 2013 06:51 PM
68Tom
Apr 3, 2009 05:33 AM
