Hellfire Oldsmobile symmetrical port cylinder heads
Old May 30, 2022 | 04:59 PM
HighwayStar 442's Avatar
Looks like the best of both worlds O & C . DX power for the win!
https://www.facebook.com/jonathan.day.376?__cft__[0
What do you do when you want to build one of the most badass Oldsmobile powered cars in the country and need a set of heads capable of making big power? Well, you build your own of course! After countless hours of design, programming, and machining Here they are! The Hellfire Oldsmobile symmetrical port cylinder heads. I started down this road about a year and a half ago when I wanted to build this car but after a conversation with https://www.facebook.com/groups/2688453731241379/user/1388332396/?__cft__[0 I quickly found out that there were no available cylinder heads available for making the power I wanted. The design went through countless revisions and iterations to get where they ended up today. I can’t say how many times I deleted my file and started over, I ended up a revision J if that tells you anything. They have a fully dry deck with external water supply with a decent amount of internal water area. These are much taller and wider than your typical Olds head to provide better port to valve approach angles. There is still lots more to do, custom valves and valvetrain. Soon these will Be off to Bill Travato at BTR performance for all the finish machine work and assembly. This is going to be one killer small block Olds!
Old May 30, 2022 | 05:29 PM
CANADIANOLDS's Avatar
Who’s heads are they?
Old May 30, 2022 | 06:30 PM
TimMC's Avatar
Very nice. Lots of skills go into cylinder heads that work. It will be interesting to watch them develop.
Old May 30, 2022 | 06:45 PM
Bill Trovato
Sorry Canadian. Facebook is blocking or it could just be me. Says 1 off, but once you have the cad program??. I knew you racers and builders would love it.
Jonathan Day - On facebook https://www.facebook.com/jonathan.day.376 Must be a hard core racer. Not my expertise. Bill Trovato to add valve etc.
One day, someone will be 3D printing thier own Olds heads.
Old May 30, 2022 | 07:28 PM
70W-32's Avatar
Peyton Hunt is also working on a Billet head
Jonathon Day Mentioned his were the 10th version he designed before milling out a useable pair.
Old May 30, 2022 | 08:22 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
What the hell do those flow? Peyton's had very impressive numbers, like 400 cfm. Those most flow a huge amount of air!
Old May 30, 2022 | 09:29 PM
Bernhard's Avatar
Wow they look impressive,hope they flow well.
Old May 31, 2022 | 05:49 AM
Peyton Hunt Billet head
Old Jun 1, 2022 | 07:04 AM
Bernhard's Avatar
Wow another impressive looking head.
Old Jun 2, 2022 | 04:27 AM
fleming442's Avatar
Who is this Jonathan Day cat? Google pointed to JJ Da Boss from MSO. I find it hard to believe that he's trying to build a SBO.
Old Jun 2, 2022 | 06:33 AM
Don't shoot the messenger! On Oldsmobile Max Performance in Facebook. Bill Trovato share the post. He is finishing the heads. I saw somewhere he a racer in the northwest.
Hunt brother's are running SBO with great successes.I believe one SBO is like 2000 HP. With Nascar or HP DX block.
Old Jun 2, 2022 | 07:06 AM
Bernhard's Avatar
[QUOTE=fleming442;1431219]Who is this Jonathan Day
He is on facebook
He is a Olds enthusiast and judging from the cylinder heads he has a good set of skills. The fact that he is working with Bill T speaks for itself.
Old Jun 2, 2022 | 08:50 AM
fleming442's Avatar
Yup. I don't do fb, and never heard the name in 20 years of being an enthusiast, that's all....
Old Jun 9, 2022 | 12:53 PM
w30442's Avatar
Nice workmanship on the heads. Shows some great skills.
Rallye469
Aug 27, 2024 04:16 AM
HighwayStar 442
Mar 11, 2022 08:44 PM
rjh45
Feb 12, 2022 05:55 PM
oldsdriver1218
Mar 5, 2020 05:30 AM
oldsy
May 11, 2010 07:40 AM
