Good non return fuel pressure regulator?
Old Yesterday | 02:46 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
The Carter mechanical fuel pump won't keep up with my new 358. I went to use an old Holley that I don't think I ever used. The 63 psi 350 LPH in tank pump pushed it to 15 psi on the lowest setting. Looking for good regulator that doesn't cost a fortune. Thanks in advance. Here is how I set up the 20 year old Holley regulator.
Old Yesterday | 05:58 PM
Basically looking at the Holley, AEM and Spectre which looks identical to the AEM but slightly cheaper. All the same style as the one I just installed.
Old Yesterday | 06:40 PM
Maybe put another one in series to drop the 15 psi down to a carburetor friendly level?
Old Yesterday | 06:58 PM
The Quickfuel 30-803 seems to rated the best out of those style regulators and will be here early next week, around $100.
Old Yesterday | 09:59 PM
That might not be worst idea. This one dropped it some, this pump is regulated a 62-63 psi just not dropping it enough for my Qjet.
Old Today | 02:49 AM
skyhigh's Avatar
1972 Cutlass Town Sedan
I got 1 from tanks inc, wish I could tell you how it preforms as Im still waiting patiently for the motor swap lol, it has a return line on it though.
Old Today | 04:39 AM
letitsnow's Avatar
It seems like it'd be real tough to drop fuel pressure that much (and keep it consistent) without a return line.
Old Today | 05:00 AM
Exactly why I might try dual regulator. Too bad there isn't real estate for a RobMc fuel pump with these heads. I don't know how the Chinese 80 gph fuel pumps perform in the real world, they have worked fine on Cutlassefi's dyno. I know I bought one years ago and never used it. I will do some searching around. Maybe it is hidden in a corner of the shop. I also did find the suction line, the clamp had bottomed out and wasn't super tight. Might not have caused an issue. I added washers to that clamp and added a second clamp since 63 psi pushing through that line.
pettrix
Jul 3, 2022 09:21 PM
shiftbyear
Nov 12, 2018 05:46 PM
Cutlass Fan
Jun 24, 2017 07:28 PM
My2nd 69 442
Sep 22, 2016 06:20 PM
jensenracing77
Nov 18, 2014 05:14 PM
