Best EFI Fuel Pressure Regulator
Any suggestions for an EFI Fuel Pressure Regulator (40-65 psi)?
Aeromotive seems like it has a good regulator
https://www.summitracing.com/parts/aei-13136
as does Holley
https://www.summitracing.com/parts/hly-12-846
I'm running an Aeromotive in-tank 340 Phantom EFI pump.
as does Holley
I chose the Aeromotive regulator. However a few months after I bought it, RobbMc brought out a regulator that seals against pressure loss (car will restart faster).
I've used many of his products and they have all been well-made. I'd get his regulator if I were buying today. https://www.robbmcperformance.com/pr...ulator_fi.html
Well, I ordered it up and should arrive next week. It's USA made and seems like a good piece for $100. Better than spending $200 on a Chinese made Holley.
What is a good PTFE fuel hose to get for EFI?
Summit sells a Fragola -6 PTFE-lined stainless fuel hose for $144 (20' length) https://www.summitracing.com/parts/fra-602026
I am running the 12-846 Holley efi pressure regulator for a few reasons…
It holds the pressure rock solid at 43psi.
It has large internal passages and will bypass a ton of fuel so it doesn’t cause fuel pressure climb when you use very large pumps. I am currently running dual 340lph pumps and it has no problem with pressure creep.
It is a Holley, so it will have parts support for likely a long time when I need a rebuild kit (spring, diaphragm) or parts.
I bought it open box for $80 from a guy who decided to stay carbureted…
No squeal or noise when working (I had an aeromotive regulator that always had a high pitched humming sound at the pressure I needed to run-55psi on that one and it was rated to 75psi), also, I had problems with getting service parts from Aeromotive.
I run large fuel rails with 3/4 ID and an 8AN inlet, connector hose, and 8AN return to the regulator inlet, which then has a 6an return line.
My pressure side is plumbed with 8AN all the way to the rails, running Earls (I think) line in and out, but it is not PTFE, but will work and withstand pure ethanol.
All of the name brand companies make good PTFE hose, just find the best deal and make sure the fittings you want to run will work with it.
If you think you will step up the power later (550hp+) on with boost or more horsepower NA, go with an 8AN pressure line instead of -6an, as -8AN as been proven to well over 900hp.
I got the RobbMc Fuel Pressure Regulator as it had good reviews, is USA made and is billet. Plus the price at $100 was a good deal for an EFI regulator. Hopefully it works out well.
I read that the 700 HP Hellcat uses a -6AN (3/8") fuel pressure line so the claim is that -6AN lines are good to around 750-800HP with EFI. On a carburetor that sees only 5-7 psi instead of 40-55psi, a -8AN line is needed for carburetor applications that see 500HP+. The higher pressure of EFI will allow for more fuel flow with -6AN. Carb guys that go north of 500HP+ and only have a -6AN (3/8) line run the risk of running out of fuel in WOT 1/4 mile runs. Especially guys running stock Q-Jets which had really poor fuel retention.
I am going with the Fragola PTFE -6AN fuel line. The problem I have discovered with rubber lines is that they have a 5-7 year life even with gasoline (10% Ethanol) and that drops down to 3-5 years for E85. The line gets brittle and starts to permeate fuel vapors through the line. There is a reason WHY modern cars use steel lines and special polymer lines when it comes to areas that require movement. PTFE lines cost more but well worth it.
Gates Barricade EFI Hose
Napa sells Gates Barricade which is an excellent low permeation hose for use with modern fuels. It is designed to withstand long-term exposure to ethanol in the fuel. I used this on my project where the hoses wouldn't be seen. Here's a link.
Rodney
https://www.napabeltshose.com/~/medi...hure.pdf?la=en
Rodney
Your Holley is a good fuel pressure regulator. You got a great deal at that price.
I tend to go overboard with hose and battery cable sizes!
I know -6AN will hold a lot of power, but I always like lots of headroom for volume.
The PTFE hose is great and will last a long time. That Gates barricade hose looks good also; I bet it can only be used with anything but barb fittings and spring clamps.
I also have pie-in-the-sky horsepower hopes for the future, so I went with -8AN….
There is non-ethanol premium, e10 premium, and E85 available near where I live. I currently only run non-ethanol premium in it.
The future for me might mean boost or some bottle feeding…. Depending on how the ol’ block holds together.
Charlie_brown
October 30th, 2009 08:54 AM
