Electric fuel pump in tank
Old Nov 12, 2018 | 12:44 AM
shiftbyear's Avatar
Does anyone make an in tank low pressure fuel pump for carbureted Oldsmobile's, 1970 Cutlass? All I can find are high pressure efi conversion pumps. I would like to have the pump in tank without doing any major surgery or using a pressure regulator if possible. Thanks.
Old Nov 12, 2018 | 06:50 AM
oddball's Avatar
Yeah, that'll be tough. High pressure pumps are just *capable* of high pressures. The actual pressure generated depends on the complete system and especially the regulator.
Unfortunately you're probably stuck with needing a regulator. Get a low pressure regulator for use with the carb and you're fine. I'm running a pump for an F250 with a Qjet and RobbMC's regulator.
The only in-take pump that, IMO, can be installed with a minimum of fuss and isn't junk is the Aeromotive Phantom. Even then, "not junk" is not an absolute.
Old Nov 12, 2018 | 07:19 AM
w-30dreamin's Avatar
71 & 72,now I want a 68
I've been looking around at in tank pumps and haven't found any with low pressure for carbs.
All I have seen will require a regulator. Will also require a fuel return line if your car is not already equipped.
Tanks Inc uses Walbro pumps,supposed to be high quality.
Old Nov 12, 2018 | 11:21 AM
Dockolds's Avatar
www.aermotiveinc.com/gen2_stealth_tank
Old Nov 12, 2018 | 11:23 AM
Dockolds's Avatar
correction
www.aeromotiveinc.com/gen2_stealth_tank
Old Nov 12, 2018 | 11:45 AM
shiftbyear's Avatar
Docolds, thanks for posting. It's exactly what I was looking for!
Old Nov 12, 2018 | 05:46 PM
danktx's Avatar
low pressure intank pumps
There is an alternative depending on what its use will be. Chevy Monzas had low pressure in tank pumps back in the 70's and 80's.
Fuel Pump Inlet TypeStrainerGasket or Seal Included Yes
Inlet Fitting Thread Size N/A
Maximum Flow Rating 29.40
Maximum Pressure 3.80
Minimum Free Flow Rate 23.00
Minimum Pressure 2.20
Outlet Outside Diameter 0.3125
Outlet Quantity 1
Outlet Type For Hose
Pump TypeTurbine
Regulator Included No
Strainer Included Yes
Voltage 12
DRoger5739
Jul 7, 2020 11:05 PM
rket56
Aug 11, 2017 05:27 AM
Hillbilllystarfire
Jun 25, 2017 12:54 PM
Cutlass Fan
Jun 24, 2017 07:28 PM
jensenracing77
Nov 18, 2014 05:14 PM
