Dyno Testing the Big Block Olds Part 9
Old Dec 2, 2025 | 11:00 AM
  #41
It'll be interesting to see how this performs. I have to believe there were more than a handful of these made and tested. Hell, you'd use up a few just in machining set-up. They likely had 5-ish parts they ran on the dyno and then scrapped them once the testing was done. I'd love to know how the two mentioned above 'made it out alive'!
I don't know where Kryta got his, but I found mine at the old performance parts swap meet at OCIR in about 1981. When OCIR shut down, that became the current Long Beach performance parts swap meet.
Old Dec 2, 2025 | 12:52 PM
  #42
OLDSter Ralph's Avatar
I designed (and reverse engineered) various cylinder heads in the Detroit area in the '90's. If someone was interested in reproducing one of these cross-ram intakes to actually reverse engineer the performance (not just a visual representation), yes, silicone molds of the runners are the easiest/simplest way to go. This happens every day on various parts. Pull the solidified mold and scan that. What you get is (usually) point cloud data which can then be 'turned into' an actual 3D CAD model with surfaces. Depending on the quality of the scanner, it may be able to 'see' a good ways into the ports but it still relies on 'line of sight' so it won't get everything. If you really wanted to get serious about it (and didn't want to cut open an original part), MRI technology is used a lot today to 'see' inside castings. You're usually looking for porosity but it can give you a good view of interior compartments.
Based on where Joe P got his manifold, I am guessing it was leftover from a racing program. That makes me think it didn't escape from the factory. It likely ended up in a corner of the shop after something newer and better came along. When the racing program was disbanded, the parts remained in the corner and someone spirited it away later and it was sold.
cdaolds
Oct 9, 2023 07:22 AM
Clark455
Apr 28, 2022 11:20 AM
EsoWuhn
Mar 30, 2020 05:35 PM
Bernhard
Nov 12, 2012 07:05 AM
RAMBOW
Nov 26, 2011 03:55 PM
