need timing tab!!
Old February 25th, 2015, 08:11 PM
major noob
billmerbach's Avatar
need timing tab!!
I need a time.ring tab so I can time my car 350 rocket
billmerbach is offline
Old February 26th, 2015, 04:51 AM
ROCKETMAN269V's Avatar
Question need timing tab!!
Which one? There are a few different ones; some metal, some plastic, depending on the year (points vs HEI). I have most, if not all, of them. Thanks, Bob.
ROCKETMAN269V is offline
Old February 26th, 2015, 06:56 AM
major noob
I have a 70350 with hei
Old February 26th, 2015, 07:35 AM
major noob
I'm assuming I just need the metal one I didn't know they had different types
Old February 26th, 2015, 08:27 AM
Timing tab
You should use the plastic one with HEI, to accommodate the additional advance built into those distributors.
Last edited by ROCKETMAN269V; February 26th, 2015 at 08:31 AM. Reason: fat fingers
Old February 26th, 2015, 08:30 AM
major noob
Your message didn't post
Old February 26th, 2015, 08:39 AM
major noob
Ok would it matter if I did use the metal one.....does the plastic one just have more numbers
Old February 26th, 2015, 09:31 AM
Yes. I don't remember exactly, but the early metal ones go to 10°, the later ones go to 10 or 12°, and the plastic ones go to 20 or 22°.
MDchanic is offline
Old February 26th, 2015, 09:33 AM
major noob
I'd like to have metal I can always use a timing tape though cant I
Old February 26th, 2015, 09:37 AM
Sure. Or just mark the balancer in the important places, which is easier to see and work with anyway.
And your motor originally had the newer type metal timing tab.
MDchanic is offline
Old February 26th, 2015, 09:39 AM
major noob
Ok then I need that one rocket man
Old February 26th, 2015, 11:05 AM
Oldsdruid
rocketraider's Avatar
You need one for an HEI engine. They have a little higher scale due to the higher base timing HEI cars use. Points tabs usually don't go much past 12 degrees.
This would probably be a plastic one. They all attach to the block the same way, meaning you might have to remove PS pump bracket. It uses a special double-ended bolt too IIRC (one to hold PS bracket on and one to mount the tab and bolt it on) and there is a small dowel on the timing cover to help you locate it correctly.
rocketraider is online now
Old February 26th, 2015, 11:07 AM
Why not just get both, Bill, and you can decide which you like to use better?
I'm sure Raider won't gouge you.
MDchanic is offline
Old February 26th, 2015, 11:10 AM
major noob
Haha I got a guy on Facebook who has a metal one he's gonna send out Saturday to me for free lol
Old February 26th, 2015, 11:43 AM
Great! Then you can do the job right.
Get everything cleaned up and ready when you can, so you can just jump right into it.
And let us know once you've got some numbers.
MDchanic is offline
Old February 26th, 2015, 11:45 AM
major noob
Its a metal one so I'll have to do a little guessing but at least I won't have to guess about tdc
Old February 26th, 2015, 11:46 AM
major noob
And I don't have money for a plastic one lol
Just use the timing tape, either pasted on, or as a ruler.
MDchanic is offline
Old February 26th, 2015, 11:49 AM
major noob
Will do thanks till I get the tab I'm taking her easy although yesterday was fun I peeled out the gas station tires spinning for about 50 feet lol
Old February 26th, 2015, 11:53 AM
Don't PO the gas station owner, or he won't see you any more gas.
That's like POing the bartender.
MDchanic is offline
Old February 26th, 2015, 11:55 AM
major noob
Haha I won't I had got the carb jetted and stuff and timed it by ear and I had to see how she did needless to say she did well
Steve O
December 12th, 2008 09:22 AM
timothypaul
October 15th, 2008 09:18 PM
griz
September 24th, 2008 05:09 PM
Ducman
November 14th, 2007 09:21 AM
Huron
July 12th, 2007 06:02 AM
Quick Reply: need timing tab!!
