need timing tab!!
Timing tab
You should use the plastic one with HEI, to accommodate the additional advance built into those distributors.
Last edited by ROCKETMAN269V; February 26th, 2015 at 08:31 AM. Reason: fat fingers
You need one for an HEI engine. They have a little higher scale due to the higher base timing HEI cars use. Points tabs usually don't go much past 12 degrees.
This would probably be a plastic one. They all attach to the block the same way, meaning you might have to remove PS pump bracket. It uses a special double-ended bolt too IIRC (one to hold PS bracket on and one to mount the tab and bolt it on) and there is a small dowel on the timing cover to help you locate it correctly.
Steve O
December 12th, 2008 09:22 AM
