“1970-2” Cutlass console parts needed.
Old Apr 28, 2024 | 05:22 PM
Funkwagon455's Avatar
I am looking for a 1970-2 Cutlass center console glove box lid with hinge and liner as well as a manual transmission insert for the console. Thanks much for your assistance.😀
Old Apr 28, 2024 | 05:28 PM
lshlsh2's Avatar
71 cutlass convertible
Do you want any color for the lid?
Old Apr 28, 2024 | 05:33 PM
70Post's Avatar
What is the "insert" you are referring to?? The woodgrain/"chrome" insert?? The "adapter" that holds the upper/outside boot?
Clarify.
Yes, I’m pretty sure that they are all cast in black dyed to the prescribed color, so I figured fuchsia is probably acceptable.😂. Thank you for your reply.😀
Old Apr 28, 2024 | 05:38 PM
Clarify.
Thank you Patton, It’s been an exhausting week for me. (Sun/wind) I’m ready to go back to work tomorrow for some rest and relaxation!! I’m needing a center console two piece glovebox insert for a ‘70-72 Cutlass.
Old Apr 28, 2024 | 06:31 PM
70Post's Avatar
Again, what is the "manual transmission insert" piece?
Old Apr 28, 2024 | 06:49 PM
Thanks again for your inquiry Patton, I’m very seriously considering a manual conversion for my wagon. I am considering converting my dual gate console auto to a manual transmission console…. If I can manage to find the right bits to make it happen at a price point that is reasonable at my limited income level, like to do so. Perhaps I’m unreasonable, but I’d like to test the waters!😀. As always, thank you for your continued application of knowledge and support!! I’m also seeking a manual transmission console insert.
Old Apr 28, 2024 | 09:09 PM
paulolds's Avatar
Pm sent
Old Apr 29, 2024 | 01:42 AM
Shredder's Avatar
Clarify.
I bet he means the 2 plastic halves that actually create the floor of the glove box.
Old Apr 29, 2024 | 08:57 AM
70Post's Avatar
He did say he needs that but he ALSO mentions something related to the manual transmission. Console glovebox liners are the same - auto or 4 spd manual.
Maybe he's referring to this setup??? (pic)
Old Apr 29, 2024 | 09:43 AM
Yes, I’d like to get the manual insert above, as well as the console lid with hinge and the two piece console glovebox insert. Apologies for the delay in response
Old Apr 29, 2024 | 09:52 AM
Thanks Paulolds!
Old Apr 29, 2024 | 12:54 PM
Loaded68W34's Avatar
Be aware. The dual gate consoles have an area cut out for the shifter plate that the regular auto and manual inserts may not cover (bottom diagram in image below). You may want to see if the wood grain inserts are tall enough to cover the knock out from the dual gate shifter plate before cutting the hole for the 4 speed insert.
As for the manual insert itself, I used the reproduction available from the parts place and others. It is a nice piece overall.
https://www.thepartsplaceinc.com/pro...and-clips/9846
Installed in my car:
Old Apr 29, 2024 | 05:11 PM
[QUOTE=Loaded68W34;1567411]Be aware. The dual gate consoles have an area cut out for the shifter plate that the regular auto and manual inserts may not cover (bottom diagram in image below).
Thank you for sharing your experience, knowledge on this subject. This experience saves others a great deal of time and money.
Old Apr 30, 2024 | 11:14 AM
Shradezz70S's Avatar
I purchased the same one fits perfectly.
GN1220
Dec 16, 2021 07:31 PM
MidNight Rider
Mar 13, 2017 06:56 PM
olds3442
Feb 23, 2016 04:27 AM
Justa car guy
Oct 9, 2012 12:34 PM
Limey
Feb 10, 2010 08:54 PM
