Scrap inner fender
Old Feb 22, 2020 | 10:52 AM
Hdmike444's Avatar
Scrap inner fender
Hi all,
does anyone have a scrap inner fender they can cut a chunk off and send me? I’m going to get a plastic welder and try and repair the torn holes and I’m guessing stock plastic will be the best thing to use. I don’t want to buy a whole new(used ) one as its not worth it. Unless there is someone local with a good cheap one.
FYI it’s a 72 442 with black wells
thx mike
Old Feb 22, 2020 | 11:55 AM
Hdmike444's Avatar
And obviously I’d cover shipping
Old Feb 23, 2020 | 02:05 AM
jollyolds's Avatar
got it -pm sent
Old Feb 29, 2020 | 12:27 PM
rocketscientis's Avatar
Plastic welding
No point trying to use anything other than same material for filler
looks like jolly has this
good luck
Dont rush it
Old Feb 29, 2020 | 01:55 PM
Hdmike444's Avatar
I actually just sent him an email and said don’t bother to send it
the plastic welder I got from harbor freight had plastic sticks and they worked fantastic
its not perfectly smooth but worked great, I had one that didn’t hold but now I have 3 instead of none, the other 3 are rock solid!
Old Feb 29, 2020 | 04:03 PM
BackInTheGame's Avatar
Nice! Hope it holds long term for you.
Old Feb 29, 2020 | 04:09 PM
Hdmike444's Avatar
Me too
i was really
pulling on it and it seemed great
Old Mar 2, 2020 | 05:40 PM
RetroRanger's Avatar
72 Olds CS
good job use a little antiseize when reassembling, they usually rip out when the fastener is stuck and twists the plastic
Old Mar 2, 2020 | 05:50 PM
Right on
I use a hss tap & drill escpecialy if captured nuts are old in a vise
& if its not a show car or if its unseen.... Epoxy th bastdards so they dont spin...good to see someone whoopin th plastic back in shape.. R u ready for dashes & consoles?? Headlight plastics & grills ?!!??
Repaired 69 grill pictured
World needs more plastic welders use good ventilation !!!
Old Mar 2, 2020 | 06:49 PM
Hdmike444's Avatar
I did use never seize on them
im not even close to trying to patch anything that needs to look good haha
meoff
Care and Appearance
Dec 2, 2019 05:31 AM
72455
Body work
33
May 30, 2019 08:03 PM
scrappie
Body work
Sep 9, 2018 07:57 AM
Ceilingman
Feb 21, 2013 12:34 PM
Gary's 2 442-S
Body work
Jan 21, 2012 06:52 PM
