1984 old custom cruiser wagon
Old Sep 21, 2018 | 12:14 PM
philjr's Avatar
I STILL NEED THE DRIVERS SIDE POWER DOOR LOCK SWITCH IF ANYONE HAS ONE. MINE HAS THE BROKEN PLASTIC EARS THAT THE BOLTS HELD THE SWITCH UP WITH BROKEN.. THANKS FOR ANY HELP ANYONE CAN GIVE ME.
PHIL SCOTT
philjrgpp@hotmail.com
Old Sep 21, 2018 | 05:03 PM
CRUZN 66's Avatar
Olds Fever
Phil, if you post a photo of the switch and where it is mounted to the door panel, I will check my stock and see what I have... I didn't pull any switches out since you said you were purchasing one online...
Old Sep 22, 2018 | 03:06 AM
philjr's Avatar
JOHN, I DID GET ONE ON LINE AND THE SWITCH IS CORRECT AS FAR AS THE PLUG IN END BUT WAY TOO BIG TO FIT INTO THE HOLE IN THE PANEL. THE ORIGINAL BOLTED UP FROM THE BOTTOM. I WILL TAKE A PICTURE OF IT AND SEND IT TO YOU. THIS SWITCH HAS TWO SMALL BOLTS UNDERNEATH HOLDING IT UP FROM THE BOTTOM INTO THE PANEL ON THE DOOR. THESE ARE THE BEST I COULD DO. THEY ARE A LITTLE BLURRY BUT YOU CAN SEE TWO "EARS" STICKING OUT AND POINTING AWAY FROM THE SWITCH AT BOTH ENDS ON OPPOSITE SIDES. . THE SWITCH PANEL IS HELD IN BY ONE PHILLIPS HEAD SCREWS AT THE REAR. IF YOUR SWITCH HAS TWO SMALL BOLTS HOLDING IT UP TO THE PANEL FROM UNDERNEATH THEN IT IS THE RIGHT SWITCH. THANKS FOR THE REPLY JOHN. PHIL SCOTT
Old Sep 22, 2018 | 03:22 AM
philjr's Avatar
1984 olds custom cruiser wagon
John, i will send you a pic of where the switch is mounted in the car when it gets light out. It is in a panel on the left drivers door in the front of the arm rest. The power window switches are in the same panel. The door lock switch is the front switch by itself.
Phil
Old Sep 22, 2018 | 05:07 AM
philjr's Avatar
JASON. HERE ARE PICS OF THE SWITCH PANEL IN THE DRIVERS DOOR. PHIL
Old Sep 22, 2018 | 03:33 PM
CRUZN 66's Avatar
Olds Fever
Phil, I will check my stock tomorrow and see what I have available...
Old Sep 22, 2018 | 03:48 PM
philjr's Avatar
Thanks john. I really appreciate the help;. Hard to find things for these cars since most have been destroyed. I want to keep it original and everything working. Thanks again.
Phil scott.
Old Sep 23, 2018 | 03:26 PM
CRUZN 66's Avatar
Olds Fever
Checked my stock today and this is what I found... I do have a few of these available... If you are still interested, you can email me at: DIEHARDOLDS@NYCAP.RR.COM to discuss cost and finalize payment and shipping details... You may still have my email from our last transaction for the head light bezels...
Old Sep 23, 2018 | 03:50 PM
If the switch you're looking for is the same as the one in the 1984 Ninety Eight, I can check the one in the local boneyard for you.
Old Sep 23, 2018 | 04:12 PM
philjr's Avatar
Thanks a million for your reply and help. I found the assy and switch from another member. Again i really appreciate your kindness and help;. Phil scott
philjr
Sep 17, 2018 05:16 PM
foulpalamont
Apr 8, 2018 06:43 PM
wisniows
Jun 13, 2014 04:44 AM
dlinderm
Sep 15, 2010 05:52 AM
