WANTED: Rocker Stands 400 67
Looking for (3) Rocker Stands to fit 67 400 motor.
Don't need rocker arms, but just the rocker stands.
These are made out of what I call 'pot metal', bolt to the head, and hold the rocker arms.
Thanks.
email directly to dflye@***.net
Thanks.
The older style 66-69 rocker setups are 4 pieces if I remember correctly.
There are 2 rocker arms, 2 small "D" shaped rocker arm pivots, and 1 strap that ties the 2 together. These were tougher steel than pot metal in my opinion.
The pot metal rocker arm setup is just the 2 rocker arms and a 1 piece pot metal bridge that ties the 2 together. The pivot and strap are 1 piece.
Which setup do you have?
yes, the Melling replacement part is as you described as well. The ones in my car were a cast alloy type part, but I have no idea if that is original or not. Was just trying to match what was in the car, but if I have to, I'll just use the Melling replacement.
Thanks,
Thanks,
