WANTED: Rocker Stands 400 67
Old Aug 20, 2009 | 06:18 PM
Flye's Avatar
Looking for (3) Rocker Stands to fit 67 400 motor.
Don't need rocker arms, but just the rocker stands.
These are made out of what I call 'pot metal', bolt to the head, and hold the rocker arms.
Thanks.
email directly to dflye@***.net
Old Aug 20, 2009 | 11:04 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
The older style 66-69 rocker setups are 4 pieces if I remember correctly.
There are 2 rocker arms, 2 small "D" shaped rocker arm pivots, and 1 strap that ties the 2 together. These were tougher steel than pot metal in my opinion.
The pot metal rocker arm setup is just the 2 rocker arms and a 1 piece pot metal bridge that ties the 2 together. The pivot and strap are 1 piece.
Which setup do you have?
Old Aug 20, 2009 | 11:07 PM
In either case Auto Zone will have Melling stock replacement parts on the shelf pretty cheap.
Part number MRM-1798 Rings a bell.
I remembered it because I'd like to have 17 Olds 98's.
Old Aug 21, 2009 | 04:57 AM
Flye's Avatar
yes, the Melling replacement part is as you described as well. The ones in my car were a cast alloy type part, but I have no idea if that is original or not. Was just trying to match what was in the car, but if I have to, I'll just use the Melling replacement.
Thanks,
Old Aug 22, 2009 | 06:17 PM
Run to Rund's Avatar
In 66 Olds went to the one piece aluminum pivot and bridge for each pair of stamped steel rockers.
Old Aug 23, 2009 | 06:50 AM
Flye's Avatar
Thanks to all. I have some stands/pivots on the way.
442rocketdave
Jun 9, 2013 02:37 PM
charlierogers
Apr 12, 2012 08:31 AM
crazy'boutOlds
Sep 3, 2011 08:15 AM
Axeni
Nov 28, 2010 09:19 AM
rtpassini
Mar 3, 2010 06:23 PM
