Wanted: OEM Motor Mounts for a 1990 Custom Cruiser with the Olds 307 V8
I can't find any Delco motor mounts for my boxy body 1990 Olds Custom Cruiser with the Olds 307 V8 on line. Does anyone know of an OEM source? I need two and a tranny mount, and I've heard aftermarkets ones suck.
Thanks,
Steve
Thanks,
Steve
If you just need something that works, Anchor P/N 2328, about $4 each at RockAuto.
The aftermarket ones are all imported. 2328s are exactly the same as the ones used on 1969-up 442s and are correct for your application. You can pay $35 each for these from an Olds specialty vendor and they will arrive in the same Anchor box as the $4 ones from RockAuto. I've personally never had a problem with the Anchor mounts, other than I've had one that the mounting holes to the block were mis-drilled. I few seconds with a die grinder fixed that.
Nemesis
February 4th, 2018 12:39 PM
