Wanted: OEM Motor Mounts for a 1990 Custom Cruiser with the Olds 307 V8
Old May 22, 2020 | 10:00 PM
smparr's Avatar
I can't find any Delco motor mounts for my boxy body 1990 Olds Custom Cruiser with the Olds 307 V8 on line. Does anyone know of an OEM source? I need two and a tranny mount, and I've heard aftermarkets ones suck.
Thanks,
Steve
Old May 24, 2020 | 11:40 AM
Fred Kiehl's Avatar
If they are the same as the LO3/5, you can get urethane inserts that will last virtually for ever.
Old May 24, 2020 | 12:09 PM
The LO3/5 motors are small block Chevy motors and are completely unrelated to what the OP is looking for.
Thanks,
Steve
If OEM motor mounts are the only thing you will accept, good luck. I'm pretty sure they are long out of the parts network.
If you just need something that works, Anchor P/N 2328, about $4 each at RockAuto.
Old May 25, 2020 | 01:02 PM
smparr's Avatar
I was looking for OEM but if anyone has good experience with an aftermarket brand please let me know which. They're just seems to be a lot of bad publicity for them online.
Old May 25, 2020 | 01:07 PM
The aftermarket ones are all imported. 2328s are exactly the same as the ones used on 1969-up 442s and are correct for your application. You can pay $35 each for these from an Olds specialty vendor and they will arrive in the same Anchor box as the $4 ones from RockAuto. I've personally never had a problem with the Anchor mounts, other than I've had one that the mounting holes to the block were mis-drilled. I few seconds with a die grinder fixed that.
Old May 25, 2020 | 04:31 PM
smparr's Avatar
Thanks for the info, I'll check them out.
Old May 30, 2020 | 10:51 PM
mjrj's Avatar
Last pair of anchor 2328s I purchased back in February were made in the USA per the box.
Old May 31, 2020 | 05:49 AM
That's a pleasant surprise.
Old May 31, 2020 | 12:58 PM
smparr's Avatar
I did find 2 NOS GM mounts on eBay, $70/each, made in USA. I picked up an Anchor tranny mount on Amazon for $9.50, made in Korea.
EsoWuhn
Feb 11, 2020 06:04 PM
deadeyejedi
Jun 10, 2019 05:34 AM
The_Jeremiah
May 16, 2019 03:19 PM
Nemesis
Feb 4, 2018 12:39 PM
Redog
Vista Cruiser & Wagons
24
Nov 28, 2010 11:06 AM
