A part for my 1984 Olds 98 tilt steering column
Old Nov 27, 2021 | 07:15 PM
Charlie D's Avatar
I currently have a 1984 tilt steering wheel column with the automatic shifter in the column. I am going to go with a floor mount shifter lever. I am looking for the sleeve without the shifter **** in it. I could also use a sleeve with the shifter **** in it and use it to fabricate what I need. Thank you.
Charlie D.
Old Nov 27, 2021 | 09:41 PM
rocketraider's Avatar
Oldsdruid
Since 1984 B&C cars did not have a floor shift option I think you'll have to go back to a 1977-79 Delta "Holiday 88" to get such a part.
What you'll run into there is the 84 column uses a combination lever for turn signals, cruise control and wipers. 77-79 wiper switch is on the dash. DK if you can adapt the earlier shift bowl to the later column, and I'm also unsure if the part from a G-body Cutlass floorshift column will work.
But a 1984 Ninety Eight Custom Sports Coupe/Sedan would be a cool car for sure!😎
Old Nov 28, 2021 | 07:04 AM
The G-body part may work. According to the parts book, the 82-86 B-body and G-body shift bowl for tilt wheel column shift columns is the same P/N. That implies that the G-body bowl for floor shift can be retrofitted to the B-body column. Again, this has to come from a G-body tilt column. Non-tilt is different.
Old Nov 28, 2021 | 07:10 AM
Burd's Avatar
What about a Grand Prix part?
Old Nov 28, 2021 | 07:13 AM
That would be a G-body.
Old Nov 29, 2021 | 07:34 PM
Charlie D's Avatar
The part I need is available. Thank you guys.
I searched the web for the part numbers Joe highlighted for me. The 7836067 steering column shroud
appears to be just what the Doctor ordered. Thank you, Joe.
Charlie D.
Old Nov 30, 2021 | 04:46 AM
BTW, don't forget to post pics of your project once you retrofit it to floor shift.
Ktneal21
Dec 10, 2020 09:13 AM
charliet615
Mar 1, 2019 08:16 AM
Hoffman2099
Nov 30, 2017 06:15 PM
travisbeamon
Mar 8, 2017 09:14 AM
rcrac3r
Mar 5, 2012 05:04 PM
