Muncie shift levers needed
Old Sep 27, 2020 | 07:43 AM
Andy's Avatar
Folks, I have a 66 442, I put a 69 m-20 transmission in it, however the shift levers in the later model are for bolt mounted shift levers not the stud mounted like the earlier shift levers. I only need two levers for 1/2 gear and 3/4 gear. Anyone have a coupleto sell?
thanks
Andy
Old Sep 28, 2020 | 06:15 AM
ROCKETMAN269V's Avatar
Andy, I believe that the only difference in the levers is the size of the hole for the stud/bolt. You could probably open the center up to allow the levers to fit.
Old Sep 28, 2020 | 06:37 AM
Andy's Avatar
I tried a drill, that metal is seriously hard, ended up using a dye grinder to open them up a bit, enough to get on the levers etc but ended up wallowing the slots out more than I wanted..my fear is the will eventually get sloppy, so I figured I would get the correct ones for the trans.
Old Sep 28, 2020 | 07:48 AM
Originally Posted by Andylappin
.....................ended up using a dye grinder to open them up a bit,.............but ended up wallowing the slots out more than I wanted............
You need to hook up with "oddball" on here. He's good with amateur machining.
Old Sep 28, 2020 | 08:38 AM
Andy's Avatar
Lol. Thanks..
Old Oct 1, 2020 | 05:25 AM
newmexguy's Avatar
Look up "Wheelz" on the V8buick site. He is in florida and likely has the correct parts. Apparently has a connex or two filled with myraid parts.
STLCRZY
Jul 4, 2019 04:26 AM
truckman5000
Jul 23, 2017 06:03 PM
Chicknj
Jun 27, 2017 11:29 AM
350rocketmurderedout
Nov 12, 2014 10:38 AM
russell-t
15
Sep 8, 2012 08:21 PM
