Looking for a set of 455 headers that will fit a 72 Olds Cutlass S
Old August 12th, 2010, 07:33 AM
STR-8_CHARGIN's Avatar
If so, how much shipped to 77373?
STR-8_CHARGIN is offline
Old August 12th, 2010, 12:16 PM
Here's a the cheapest pair you can get from Summit. I don't know how good the Flowtech headers are. I have a set of ceraimc coated Hedman Hedders on my 98.
http://www.summitracing.com/parts/BIG-11154FLT/
Olds64 is offline
Old August 12th, 2010, 08:03 PM
extreme1's Avatar
16 hours to install the flowtech headers, this included relocating the brake proportioning valve, clearancing them for the steering shaft and grinding down the back of the passenger upper control arm.
extreme1 is offline
Old August 12th, 2010, 08:04 PM
extreme1's Avatar
Other companies making headers for BBO in A body.
Stainless works, Hedman, hooker, dougs.
extreme1 is offline
Old August 13th, 2010, 04:43 AM
507OLDS's Avatar
Hookers will have the best fit,thus part of the reason they cost more.You can get them with 1 7/8" primary tubes.The other ones are mostly 1 3/4" which is dated technology.You will have to relocate your brake proportioning valve regardless of whatever header you get.Just swing it up on top of the frame rail,to get it away from the header.
507OLDS is offline
72 Olds Project
October 7th, 2021 05:12 AM
tmaleck
August 15th, 2021 08:17 AM
naphtali5725
February 27th, 2015 06:27 PM
62radarlove
March 7th, 2012 04:16 AM
lou tecco
May 30th, 2011 06:04 PM
Quick Reply: Looking for a set of 455 headers that will fit a 72 Olds Cutlass S
