ISO 66 Dearborn/Phord 3 Speed Toploader Transmission
Old Jul 1, 2022 | 01:23 PM
66-3X2 442's Avatar
We need to locate and purchase a 66 442 3 speed Dearborn/Phord transmission. The ID tag should have the code HEG AB which is the code for a 442 unit. The tag is riveted to the case. I think 67 units had a different code but not sure and if you have a 67 transmission with that code we're interested.
Mike
Old Sep 21, 2022 | 11:57 AM
Oldsmaniac's Avatar
Not sure but ad says its out of a 66 442 and priced too high IMO.
https://www.ebay.com/itm/17538188718...a498%7Ciid%3A1
Old Sep 21, 2022 | 12:33 PM
66-3X2 442's Avatar
He doesn't show the date code but the tag is a 69 unit I believe. We got transmissions running out of our ears,just looking for a good date code. Thank you very much for sharing.
Old Sep 21, 2022 | 01:23 PM
Oldsmaniac's Avatar
Well seems the shifter is correct...
Old Sep 21, 2022 | 03:10 PM
66-3X2 442's Avatar
Yes it does but we have plenty of shifters also,thanks again.
Old Sep 22, 2022 | 05:11 AM
Oldsmaniac's Avatar
Where is the date code on these? What does the tag tell you? These are a mystery to me, I also have an extra Dearborn trans and wonder what date it is?
Old Sep 22, 2022 | 07:22 AM
66-3X2 442's Avatar
They are a mystery and nobody in the Olds community has ever researched them until Curt Anderson and I did some digging.There could have been some research but we couldn't find any.The tag has the Phord identification info. The lettes/numbers on the topline is the actual Phord ID and the numbers on the bottom line are production serial numbers. When the trans were used in an Olds they used a 2" ink stamp to ID the trans as the line workers didn't have time to look @ the Phord ID tag. As far as the date code goes,it's cast on the case above the front shift arm and are upside down. They are actual date codes not Julian date codes. They would be something like 6 A 15. That Jan. 15 of 1966. The Phord guys are big on these tags because they have the info for particular applications. They used the tags on 3&4 toploader transmissions,
Old Nov 12, 2022 | 12:53 PM
Oldsmaniac's Avatar
Hows this look for date?
Old Nov 14, 2022 | 10:50 AM
65B01Delta's Avatar
Found this on Craigslist.. 30 minutes from me....
https://cincinnati.craigslist.org/pt...550776267.html
Old Nov 14, 2022 | 10:51 AM
65B01Delta's Avatar
PM Sent
Old Nov 14, 2022 | 10:55 AM
65B01Delta's Avatar
This was the standard (base) factory 3 speed top loader heavy duty transmission for 1965 to 1969 B.O.P cars .GTO , Lemans, Tempest ,Buick , Olds, 442 . Rat rod . hot rod . Buick olds Pontiac $200.00 765 three three eight 7459
Very Good price.
Old Nov 23, 2022 | 05:31 PM
dbater's Avatar
Craigslist https://hudsonvalley.craigslist.org/...560291062.html
Old Nov 23, 2022 | 06:46 PM
Rallye469's Avatar
Seems a bit pricey…
But that’s up by my parents house. I’ll be up there in December.
Old Nov 23, 2022 | 06:56 PM
dbater's Avatar
Just realized it’s not the correct year that the OP is looking for.
Old Nov 23, 2022 | 07:23 PM
66-3X2 442's Avatar
Thanks anyway,appreciate the tip.
randy442
Tech Editor's Desk
Sep 23, 2022 10:09 PM
cherokeepeople
Apr 21, 2018 08:39 AM
Tymiles24
Jan 17, 2018 02:42 PM
Mar 4, 2013 07:19 AM
bisscrac
Tech Editor's Desk
Jun 5, 2012 10:39 PM
