Cutlass Speedometer Part
Old Feb 8, 2010 | 06:09 AM
we jeep inn's Avatar
The trans. position indicator mechanism is broken on my speedo. Is this part available new or aftermarket? Anybody have a used one?
Old Feb 8, 2010 | 06:28 AM
Lady72nRob71's Avatar
This should be easy to find used off a broken speedo - I have not seen repros of it anywhere and I am convinced it is not repro'ed. I saw these on busted speedos in that distant yard I went to, but I will not be back there for a while, as it is far and it floods after lots of rain (like we are having now).
While you are waiting for a replacement, try some 5 minute epoxy glue. This is a low stress area (during normal operation) and epoxy is super strong. Just a thought...
Old Feb 8, 2010 | 01:10 PM
svnt442's Avatar
Make sure you don't use super glue. It just won't hold plastic worth a damn. Get a good 2 part epoxy designed for use with plastic and you should be good to go.
Old Feb 8, 2010 | 02:47 PM
The only thing 'super glue' bonds well is skin...
Old Feb 8, 2010 | 03:31 PM
svnt442's Avatar
No kidding. It actually works quite well in a pinch on a cut if you don't have access to bandages.
Old Feb 9, 2010 | 04:29 PM
jhoppeolds's Avatar
I've got a nice used one, complete assembly with the bracket, wire hook and even the clip that bolts to the steering column. $20 postpaid to your door.
78ChevOlds
May 8, 2013 09:01 AM
kjr442
Feb 22, 2010 06:45 AM
we jeep inn
Feb 8, 2010 06:10 AM
Texas Jim
Ninety-Eight
17
Dec 30, 2009 06:28 PM
deweirdt
Jul 21, 2009 08:29 AM
