Crank Pully
The car is an a/c car but does not presently have AC and I do not plan to install. So a non a/c is fine if it will work. Presently I have an underdrive pulley and it is giving me problems because it will not charge at idle. SO I wanted to replace with a stock pulley to hopefully solve the problem.
The one you need has to be matched up to your W/P pulley and P/S pulley.
Go by the codes like crazy'boutOlds has stated.
This is from the PM, to ScottMHoffman from over a month ago.
Assembly Manual 72'. pg. 92 of sec. 6-1.
two types;
Crank Pulley Power Stearing Water Pump
#405459-code KJ is for P/S code KG, W/P code KM
#409806-code KB is for P/S code KH, W/P code KO
two types;
I spoke with him on the phone. He has aluminum heads and an aftermarket passenger side alternator bracket. (a Mondello one he believes.)
His water pump is an AC application one.
I sent him a set of vin 9 307 pullies in hopes that the small outer most pulley on the crank would be close.
It's still an inch off, so He may have to shim the mondello bracketry.
