Crank Pully
Old May 5, 2009 | 02:07 PM
ScottMHoffman's Avatar
Crank Pully
Looking for a stock crank pulley for my 455.
Old May 5, 2009 | 03:03 PM
crazy'boutOlds's Avatar
A/C, or non a/c? Any specific letter code?
Old May 6, 2009 | 07:14 AM
The car is an a/c car but does not presently have AC and I do not plan to install. So a non a/c is fine if it will work. Presently I have an underdrive pulley and it is giving me problems because it will not charge at idle. SO I wanted to replace with a stock pulley to hopefully solve the problem.
Old Jun 22, 2009 | 07:57 PM
Charlie_brown's Avatar
I've got stock pulleys out of a 76 455
Old Jun 22, 2009 | 08:11 PM
hamm36's Avatar
The one you need has to be matched up to your W/P pulley and P/S pulley.
Go by the codes like crazy'boutOlds has stated.
This is from the PM, to ScottMHoffman from over a month ago.
Assembly Manual 72'. pg. 92 of sec. 6-1.
two types;
Crank Pulley Power Stearing Water Pump
#405459-code KJ is for P/S code KG, W/P code KM
#409806-code KB is for P/S code KH, W/P code KO
Old Jun 23, 2009 | 12:13 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
I spoke with him on the phone. He has aluminum heads and an aftermarket passenger side alternator bracket. (a Mondello one he believes.)
His water pump is an AC application one.
I sent him a set of vin 9 307 pullies in hopes that the small outer most pulley on the crank would be close.
It's still an inch off, so He may have to shim the mondello bracketry.
Old Jun 23, 2009 | 06:37 PM
Hope these do!
citcapp
Nov 2, 2012 07:51 AM
Dokks74
Oct 19, 2011 03:05 PM
72 cutlass455
Jul 8, 2010 12:18 PM
SMOKEYMTNKUSTOMS
Jun 21, 2006 04:42 AM
SMOKEYMTNKUSTOMS
Feb 21, 2006 11:16 AM
