330 motor
Old Jan 4, 2013 | 03:05 PM
lilhow's Avatar
330 motor
Looking for a 330 for my 65 f85 in southern Ontario. Mine needs a complete rebuild and is already 40 over.
Old Jan 4, 2013 | 03:09 PM
Oldsmaniac's Avatar
I would have no problem going .060 on that 330...
Old Jan 4, 2013 | 03:21 PM
deaddds's Avatar
I have a complete 330 from a 65 Jetstar 88 disassembled. Not sure if they are the same numbers wise but I know several componants interchange even though I consider it a big car. It is a 4 barrell set up too. Email dead@mchsi.com if interested. Pat
Old Jan 4, 2013 | 03:23 PM
lilhow's Avatar
That's what Ive bin hearing. Did a nocar 340 and overheating maybe an issue with it haven't had it out yet. I've got it priced out $1400 in parts $1600 machine shop + our $h1t 13% tax, so I though 60 over was a bit much.
Old Jan 4, 2013 | 07:59 PM
Olds24's Avatar
330 Olds
I have one that has been rebuilt with approx 20,000 miles runs perfect! Located in Northeast Iowa. Asking $850
Old Jan 5, 2013 | 07:44 AM
copper128's Avatar
Lt. Buzzkill (ret.)
I have a standard-bore bare 330 block ('67) in the Buffalo, NY area that you can have for $50. I'd throw in a set of factory pistons and rods for free if you could use them.
Old Jan 6, 2013 | 08:13 PM
jjcus's Avatar
330 heads
I have a set of 330 heads (1965), Buffalo NY area, $175.00
Old Jan 6, 2013 | 10:52 PM
RAMBOW's Avatar
Ben
I have a good running, no smoke, drilled for M/T, High comp 330 in my car that i'll be pulling shortly for a 455 swap.
was thinking of asking $600.
Old Jan 7, 2013 | 06:09 PM
lilhow's Avatar
Hey thanks everyone. I was pmed by a member here who may have what I need a little closer to home. Sounds like some good deals though. Will know this weekend and post Thanks again Jeff
Old Jan 9, 2013 | 03:08 PM
BILL DEMMER's Avatar
Just the facts...
i don't think you'd have an issue going to std. 350 bore with that block.
bill
Old Jan 9, 2013 | 07:07 PM
tru-blue 442's Avatar
Old School Olds
HIGHJACK!
Is it true the 64-67 330's all have steel cranks as well
and can be used in 350 builds?
Old Jan 10, 2013 | 06:38 AM
ROCKETMAN269V's Avatar
HIGHJACK!
Yes, you just need to use the correct flywheel/flexplate for the crank.
Old Jan 11, 2013 | 03:27 PM
lilhow's Avatar
Ok highjacker can u use 350 heads on a 330
Old Jan 11, 2013 | 03:42 PM
stan 65 cutlass's Avatar
yes to that too,
Old Jan 12, 2013 | 07:44 PM
edzolz's Avatar
You may have to open up the pushrod slots if the 330 is any block that is 45 deg. lifter angle.
Old Jan 13, 2013 | 06:55 AM
I believe that ALL 330s were 45 deg. The only 39 deg. blocks are misc. early 400 & 425 and ALL V-8s '68 & up.
wjustinmartin
Jul 10, 2010 10:49 PM
RAMBOW
Dec 18, 2009 06:16 PM
Col Wickham
Aug 29, 2009 10:43 PM
mailmanfan
Aug 23, 2009 06:09 AM
gearheads78
Aug 20, 2009 03:18 PM
