1992 toronado
In an OBD 1 system you should be able to disconnect the battery for a few moments, and the codes should clear from the computer. Have you tried Jumping pins A and B on the OBD connector and watching the dash light? It will flash out the code. Im sure there is a Thread somewhere explaining this in more detail then I am.
You can use a paperclip or this tool; OTC 7739, to get the codes from your computer.
Follow the procedure in this thread.
https://classicoldsmobile.com/forums...mputer-123831/
