1992 toronado
Old Jun 26, 2023 | 04:19 PM
70-455's Avatar
1992 toronado
Looking for a OBD1 scanner/code reader for this car.Want one that can clear codes.
Old Jun 26, 2023 | 04:43 PM
66SportCoupe's Avatar
If you're in Minnesota I have a GM Tech 1 that we could clear codes with.
Old Jun 26, 2023 | 04:59 PM
70-455's Avatar
Gm
Im in new-jersey
Old Jun 26, 2023 | 07:04 PM
Carlarena1's Avatar
In an OBD 1 system you should be able to disconnect the battery for a few moments, and the codes should clear from the computer. Have you tried Jumping pins A and B on the OBD connector and watching the dash light? It will flash out the code. Im sure there is a Thread somewhere explaining this in more detail then I am.
Old Jun 27, 2023 | 03:25 AM
You can use a paperclip or this tool; OTC 7739, to get the codes from your computer.
Follow the procedure in this thread.
https://classicoldsmobile.com/forums...mputer-123831/
Old Jun 27, 2023 | 06:56 AM
70-455's Avatar
I disconnected the battery.but the abs light didn’t go out.
Old Jun 27, 2023 | 07:31 AM
There should be a way to pull codes and see what abs code you have through the DIC
Old Jun 27, 2023 | 07:49 AM
How long did you disconnect the battery? Even if you leave the battery disconnected over night and it clears the code, it will reset the code when you start driving again if there is a fault.
Jetmek
Oct 19, 2024 07:18 AM
70-455
Sep 16, 2022 12:12 PM
REO442
Mar 22, 2022 08:42 AM
64Rocket
Jul 17, 2013 07:36 PM
Gustav455
Dec 8, 2009 05:36 PM
