1960 dynamic 88 alt. Bracket
Old October 3rd, 2018, 10:41 PM
Rpayne's Avatar
I cant seem to find alternator brackets for 394..anybody have any idea of what can work?
Rpayne is offline
Old October 4th, 2018, 02:26 PM
D. Yaros's Avatar
That you cannot find them could be because the 1960 Oldsmobile did not have an alternator. Generators were used by Olds until 1963 model year, I believe.
D. Yaros is offline
Old October 4th, 2018, 03:12 PM
Rpayne's Avatar
Yes that is what i have on it but i would like to convert it to an alternator. Due to the new load that i will be putting it under
Rpayne is offline
Old October 4th, 2018, 04:20 PM
Phantom Phixer
Charlie Jones's Avatar
The alternator can be mounted on the bottom by the generator bracket
You will need to shim it up with washers and a length of small pipe .
Make sure the pulley aligns correctly .
The upper bracket may need to be modified .
Charlie Jones is offline
Old October 5th, 2018, 01:37 AM
jollyolds's Avatar
u can use a 63 64 394 setup-which i have if interested
jollyolds is offline
Old October 5th, 2018, 11:23 AM
D. Yaros's Avatar
X2 on the 63-64 394 engine set up. I would not be at all surprised if this bracketry is able to be found on eBay.
D. Yaros is offline
ReallyWildStuff
July 20th, 2017 06:45 PM
aristellier
August 12th, 2012 10:54 AM
aristellier
July 23rd, 2012 10:01 AM
GothamCity
January 20th, 2009 01:55 PM
cisco88
May 27th, 2008 03:12 PM
Quick Reply: 1960 dynamic 88 alt. Bracket
