E-400 engine, 7a-409147 heads, HEI, 6" WP
Old Aug 18, 2014 | 05:03 PM
Octania's Avatar
Lansing MI 48911 or near
66-67 early 400 ENGINE bored .057
Short block $800
[this is on craigslist Lansing, you can find it there, thought I would help spread the word here. I am not making $ on it or involved in any way with it.]
CORE HEADS 1972 "7a" castings 409147
getting cleaned and checked now
$200 ready to build
Great choice for a 350 or 403
Newish aftermarket? HEI unit. Lacking the module, cap, coil.
Looks barely used. $20 ??
Like a naked one of:
Amazon.com: HEI - Oldsmobile 260 - 455 V8: Automotive Amazon.com: HEI - Oldsmobile 260 - 455 V8: Automotive
WATER PUMP
aftermarket casting
6.1" x 1.8" inlet
stamped impeller, of course
Looks installed then barely used, like not at all.
$10 easy fix for your 6.1" WP blues where factory casting is not needed.
PULLEY 3 groove WP Pulley
KF, mates with KC crank pulley
for the MEDIUM LENGTH 5.6" pump according to database
but it was with/on the 1972 350 with the above 6.1" WP- probably misaligned.
How about $10 ?
Engine LIFTING STRAP "U" shaped unit from LH front corner of engine $5
TIMING TAB steel unit off the 1972 350 engine $10
Also if you need any WHEEL WELL TRIMS off the '79 Delta 88 or similar things, speak now. Rear quarter window bits? Nice pretty JACK AND BASE? Won't be there forever.
text or call 517..Four 49.oh 43 two
joepenoso
Jun 4, 2014 01:56 PM
MDchanic
Wheels and Tires
22
Aug 4, 2011 10:23 AM
Swed Olds
Nov 18, 2007 04:51 PM
Ryhelio
Jul 7, 2007 11:49 AM
