Tri Carb Intake and carbs
Old May 13, 2021 | 04:33 PM
11971four4two's Avatar
MOTORHEAD
$4999 For the intake , carburetors , mounting studs , Cross Over Block Offs , air cleaners , linkages and fuel lines
Pick UP OSSEO MN
Intake is cast with AU
Old Jun 2, 2023 | 12:24 PM
MOTORHEAD
Pictures before removal from running car
Old Jun 4, 2023 | 10:09 AM
BuddyH's Avatar
BuddyH
Tri Carb Setup
any movement in the price since 2021?
Old Jun 4, 2023 | 10:31 AM
MOTORHEAD
HI
I did lower the price to $4999 on JUNE 2nd
If you want to spend less $$ I will sell The Carbs , Linkage , air filters and fuel lines with a BARE INTAKE Manifold it is casting AZ FOR $4500 CASH
Pictures of AZ manifold....
Old Jun 7, 2023 | 03:15 PM
BuddyH's Avatar
BuddyH
Tri Carb
Ok; I’m 1,350 miles from you. Would you consider $4000 in order to cover my gas/lodging? (On the painted intake)
thanks,
Buddy
Old Jun 9, 2023 | 08:02 AM
BuddyH's Avatar
BuddyH
Carbs
Guess not…
Old Jun 9, 2023 | 08:41 AM
MOTORHEAD
HI
I was out of town most of the week.. Home late last night
You are correct NO I will not sell the AU (painted intake with block offs) and carbs etc for $4000 Thank you for the offer
I would sell the AZ BARE not painted and NO Block offs , with the carbs etc for $4000 CASH
The AU Painted intake with block offs NO CARBS etc.. $3200 or $4999 with carbs
This is picked up near minneapolis
Buyer will have to pay their own travel expenses
Old Jun 9, 2023 | 05:01 PM
BuddyH's Avatar
BuddyH
Carbs
OK, thanks for your reply. Could you explain the difference between the AU and AZ manifolds, exclusive of the paint and block offs? Thanks!
Buddy
Old Jun 11, 2023 | 09:03 PM
MOTORHEAD
HEY
I was planning to take a picture of the intakes
side by side
One of these days I will get new MORE pictures
OR
Come on over and compare them
Old Jun 12, 2023 | 08:14 AM
66-3X2 442's Avatar
Buddy
The AL/AU tri carb intakes have a uneven flange for the center carb on the front of the mounting pad. They fixed this on the AZ version with a straight mounting flange. The AL/AU intakes have about .070 of pinch/sealing area and can lead to leaking. The factory fix for this was to use a sealer on the center carb gasket. There is absolutely nothing wrong with the AL/AU intakes,they work as well as the AZ. The AL intake has a coil mounting boss in the very rear of it and makes it harder to mount. The AU/AZ have the coil mounting boss up top next to the rear carb and makes for easier mounting. There is no performance advantage between the 3 versions.
w30442
Jun 5, 2023 01:17 PM
Dec 5, 2019 04:48 PM
79Cut2Tone
Jul 23, 2015 04:32 AM
archerbob
Aug 19, 2011 02:35 PM
Kidcutty
Jun 4, 2011 08:57 AM
