Steering box help please
Old Jan 22, 2017 | 07:10 AM
brandon reynolds's Avatar
Need help. Rebuilder screwed up my numbers matching box for my 71 442. I dont want to go into detail because he has a good reputation and doing everything he can to make this right, and i think this was a one time issue. But i need a #6 steering box with a casting date of 235 and an assembly date of the 251 day of 70, or as close as possible. I know you parts horders have to have something close. Thanks brandon
Old Jan 22, 2017 | 08:24 AM
2blu442's Avatar
Power or manual steering box? I've got several from cars I've parted over the years. But have not looked closely at them. Where is the #6 on the casting number located?
Old Jan 22, 2017 | 08:54 AM
Blu sorry forgot to say power steering. The 6 is on the side of the box thats against the frame rail towards the front of the car, and the casting date is to the right od that. The assembly date is on the aluminum plate on top stamped on a little pad. See below. Thanks Brandon
Old Jan 22, 2017 | 09:50 AM
You do realize that there aren't any numbers that "match" on the steering box, just date codes that are on hundreds if not thousands of equivalent boxes.
Old Jan 22, 2017 | 09:59 AM
Yes joe I understand that there are no numbers matching steering boxes, i should have said correct date coded steering box. And i know that there are thousands and thousands in that range that will work. All the ones i had where too early or too late. Thanks brandon
Old Jan 22, 2017 | 10:30 AM
2blu442's Avatar
Sorry, I think others will be able to get closer to the date you want than I can. I found one with the right dates, but the casting turned out to be a 67. The closest I could come on a 6 casting was 211 on the low side or 314 on the high side. John
Old Jan 22, 2017 | 11:53 AM
Thanks john for looking
Old Jan 24, 2017 | 12:19 PM
Olds24's Avatar
I have a #6 box dated 287 on Body and 298 9 on cover
Old Jan 24, 2017 | 12:20 PM
thanks but my car was built on the 255th day of 1970 so that's too early.
Old Jan 30, 2017 | 12:51 PM
71Cruiser's Avatar
Try Marty at Powersteering.com
aquabird
Oct 2, 2013 10:34 PM
henryk8398
May 28, 2013 09:26 PM
morexfiles
Apr 22, 2013 12:51 PM
agtw31
Suspension & Handling
15
Jun 14, 2010 06:01 AM
drtdobber
Feb 14, 2007 01:16 PM
