Valve Cover Paint??
Old Sep 16, 2018 | 06:03 PM
quadpack67's Avatar
Valve Cover Paint??
I am getting ready to replace my valve cover gaskets and I want to repaint the covers. They are a blue of some sort and I need to know exactly what color to keep it original. I have a 1976 Cutlass S Y76. It has the original Oldsmobile motor in it. If I can get a paint code, that would be wonderful!!!
Old Sep 17, 2018 | 07:47 AM
Welcome. All 1976 V8s were GM Corporate Blue. That should be readily available since Chevys used the same color. Plastikote 221 is one version.
Old Sep 18, 2018 | 07:58 PM
quadpack67's Avatar
My husband was under the impression that there was a distinctive blue on different models ie: Oldsmobile Blue, Pontiac Blue, Chevy Blue, etc. Any input???
Old Sep 18, 2018 | 08:06 PM
Again, by the 1976 model year, Oldsmobile had stopped using it's distinctive metallic blue for 455 motors (as well as the gold for 350 motors) and only used the corporate blue on every V8 it built.
Old Sep 18, 2018 | 08:17 PM
Here is a 1975 Olds 350, with corporate blue paint from the factory instead of Olds gold. 455 motors used the same corporate blue by then.
Old Sep 18, 2018 | 08:24 PM
quadpack67's Avatar
Thank you for the info. Just trying to learn the history of everything.
Old Sep 19, 2018 | 05:09 AM
rob1960's Avatar
I thought corporate blue didn't come out 'till 77. Back in '09 I completely went through my girlfriends '76 Salon. It was an untouched 43k car at the time,it was leaking fluids everywhere & it needed some TLC!!. It has a 350 & it was metallic blue like the big-block blue but it seemed to be more of a saffire color but it was very thinly applied!!. The engine had never been apart & it still had the "timing ok" ink stamp on the valve cover. It was definitely a metalic blue paint. I repainted the engine in Olds blue as it was the closest color.
910hemingway
Oct 14, 2014 06:06 AM
Blackpage
Paint
43
Nov 6, 2013 01:25 AM
CS455
Jul 11, 2012 11:29 AM
70special
Paint
15
Dec 4, 2010 04:25 AM
hinz57
Paint
Apr 14, 2010 06:11 PM
