Trunk splater paint question
Old Dec 10, 2018 | 01:19 PM
AJFink's Avatar
I bought the paint from Eastwood and got it put on this weekend, turned out great but I sprayed it over DP90 black primer.
Anyway can says, I should put the clear over it......Do I really need too? has anyone else used this and not put the clear over it? it is Zollitone in a shaker can.
They surly didn't put clear over it from the factory.
Old Dec 10, 2018 | 03:48 PM
forddom's Avatar
Hey AJ , that splatter paint is basically water base so the clear seals it. if you have no clear and it gets wet it will soften and come off.
I would def clear just go lightly. the factory one was not cleared but also wasn't water base. Good Luck
Old Dec 10, 2018 | 04:14 PM
AJFink's Avatar
Sorry but what is def clear?
Old Dec 10, 2018 | 04:51 PM
RandyS's Avatar
He meant DEFINITELY clear coat it. As mentioned, it is water based and will be ruined if it get's wet. It also scratches fairly easily, and the clear protects it. I put at least 2 full coats of clear flat over mine (after having to re-paint an area that had gotten wet before I 'clear coated' it).
Old Dec 10, 2018 | 04:52 PM
oldolds88's Avatar
definitly
Old Dec 11, 2018 | 08:14 AM
oldsmobiledave's Avatar
It is SPATTER not splatter. I wonder why so many people in our hobby get this wrong?
Old Dec 11, 2018 | 08:15 AM
AJFink's Avatar
Looks like I'll be clear coating go some PPG 2021 that should do it.
pureplaya442
May 3, 2019 02:50 PM
Thomas Simcich
Paint
Oct 21, 2011 07:56 AM
scott strange
Paint
Oct 20, 2010 07:57 PM
Ranzan
Feb 14, 2010 04:46 AM
nukesec1
Paint
Jan 14, 2010 06:06 AM
