Removing paint overspray from interior
Old Apr 1, 2010 | 03:05 PM
msco123's Avatar
Ok, I know you get what you pay for. I thought I was getting a bargain paint job and what a piece of crap. I now have paint overspray on dash, seat, basically whole interior. How do I clean this off?
Old Apr 1, 2010 | 03:18 PM
66ninetyeightls's Avatar
Land Yacht Captain
You could try some Acrysol or paint thinner. Try them on spots that are not visible first to make sure they don't affect the factory finish first.
Old Apr 1, 2010 | 04:45 PM
MJAKS462's Avatar
Carb cleaner works great to take anything off , but I would hate to see you ruin your interior using it. I would try a real small spot and let it dry and see how it looks.I use it on wires to clean off paint and grease .
Old Apr 1, 2010 | 06:27 PM
msco123's Avatar
Yeah, I sure as hell would hate having a screwed up interior.
Old Apr 1, 2010 | 07:18 PM
rocketraider's Avatar
Oldsdruid
There is no excuse for getting overspray inside the car. Any painter worth a hoot should know how to tape off and mask a door or window opening to prevent it.
I'd have it professionally cleaned, and then I'd send the painter the bill with a letter from your lawyer.
Old Apr 1, 2010 | 07:30 PM
msco123's Avatar
I don't have any recourse since the car was painted at a prison body shop by a convicted murderer (no kidding). The guy was supposed to be a Ford certified body man. Goes to show you just can't trust criminals. This is a true story.
Old Apr 1, 2010 | 07:54 PM
70 cutlass s's Avatar
Since that's the story then your screwed. Try mineral spirits. Take some and put it on a rag then clean the over spray.
Old Apr 1, 2010 | 08:46 PM
Land Yacht Captain
Pay another inmate to shank him for ruining your ride!!!
Old Apr 1, 2010 | 08:52 PM
chequenman's Avatar
Exclamation
Kinda tacky Craig, but right to the Point.
Limey's Avatar
Goof Off, not kidding let it soak in for a little bit and use 0000 grit steel wool so not to scratch the vinyl SOFTLY ( softly is the key word here )
Old Apr 1, 2010 | 08:58 PM
chequenman's Avatar
Originally Posted by Limey
Goof Off, not kidding let it soak in for a little bit and use 1500 grit steel wool so not to scratch the vinyl SOFTLY ( softly is the key word here )
Goof Off is for removing Latex Paints not Automotive Base/Clear or Single Stage urethanes. Goof Off won't touch automotive finishes, unless you are scrapping it off with a Razor Blade.
Old Apr 1, 2010 | 09:00 PM
Limey's Avatar
well it worked fine for my fiance's car that the painter didnt mask all the crap off as well
Old Apr 2, 2010 | 04:26 AM
MN71W30's Avatar
Wax and gease remover/Naptha/DX330/ lighter fluid, it's pretty much the same stuff. Get a gallon and a rag and get scrubbing. Try a spot to make sure their isn't a problem.
Old Apr 2, 2010 | 06:54 AM
442scotty's Avatar
Go to a body shop supply store and get a product that removes overspray...I use one that comes in a container with pull out wet wipes...its made for doing this...I dont have the name right now cause its packed away but it works well on vinyl, glass etc and took my acrylic urethane off pretty quick......Even with all of my windows well taped some overspray managed to get in somehow. I will try and find it and print the brand...
Old Apr 2, 2010 | 07:06 AM
msco123's Avatar
Thanks, I appreciate any help.
Old Apr 2, 2010 | 09:09 PM
ent72olds's Avatar
Registered Luser
Go to the autobody supply and get the clay bar and the proper spray. Like everybody else said, try it on a hidden spot first.....
Old Dec 22, 2011 | 10:00 PM
scumdog's Avatar
Kiwi Ciera Driver
Haven't read all the replies BUT:
If it on vynil upholstery etc use brake fluid.
Wipe it onto the areas you want to take the overspray off and leave overnight.
Wipe down with a damp rag & rinse carefully..
May take two attempts.
WARNING: Brake fluid is not fussy what paint it removes - do NOT put it onto a surface already painted to take the overspray off for instance.
It is ideal for vynil, plastic/rubber glass etc.
Old Dec 23, 2011 | 06:25 AM
... the car was painted at a prison body shop by a convicted murderer (no kidding).
I know this is a zombie thread, but...
Goes to show you can't trust Factory-Certified mechanics!
Old Dec 23, 2011 | 06:53 AM
Lady72nRob71's Avatar
Oven cleaner works great for removing overspray from plastic. The smell & fumes are horrible though.
NTMD8TR
Paint
Sep 17, 2014 09:45 PM
guycaso
Feb 1, 2011 12:27 PM
jensenracing77
Paint
Jul 13, 2010 06:58 PM
oldzy
Nov 20, 2009 05:38 AM
68Tom
Paint
Mar 6, 2009 07:30 AM
