Paint match on panels?
Old Sep 19, 2018 | 03:04 PM
Platinum69's Avatar
My buddy just painted my car silver. He painted the panels separate and then put together, was over today to look at it. Some of the panels look slightly different shade than others. now that they are on car. He says it's the lighting, says wont notice once its outside. Does this sound likely? I am very picky, maybe it's not as big a deal as I think. Gonna go over tomorrow and pull it outside to see if it looks better. Thanks
Old Sep 19, 2018 | 03:59 PM
Can you post some pictures?
Old Sep 19, 2018 | 04:24 PM
Platinum69's Avatar
Not sure if its lighting or what, but the deck lid looks darker to me
Door looks slightly darker, from the right of the photo is a window with natural light comin in.
Old Sep 19, 2018 | 04:36 PM
ragz442's Avatar
The panels need to be assembled when spraying metallics. It will probably be less noticeable outside though.
Old Sep 19, 2018 | 05:00 PM
RandyS's Avatar
Looks great to me!
Old Sep 19, 2018 | 05:06 PM
Platinum69's Avatar
Yeah, I'm very happy with quality of work and straightness. I wanted a nice driver quality car not a show car. I'll get it out In the light tomorrow and see. Thanks
Old Sep 19, 2018 | 05:33 PM
Yeah, it looks pretty good under the fluorescents. But get it out in the sunlight if you want to see if there are any flaws. Always works when I'm polishing mine -- looks great in the garage but it's a mess once I get it outdoors.
Old Sep 20, 2018 | 04:39 AM
Also, ask your buddy if he is going to buff the paint. Even a professional painter can't lay down the paint perfectly. Buffing it will remove all the little imperfections.
Old Sep 20, 2018 | 05:17 AM
Platinum69's Avatar
He already buffed,that parts looks good to me. He said one final buff before I take it.
Old Sep 20, 2018 | 06:58 AM
^^^THIS! Metallic paint shades can vary with application technique and even direction. Back when we were all spraying lacquer, it was easy. You simply over-thinned the final coat by 50% and sprayed at 90 degrees to the prior passes. This fog coat "melted" the previous layer and helped flow the metallic. Modern BC/CC paints don't work that way, so your technique needs to be perfect.
Old Sep 20, 2018 | 07:05 AM
I was actually wondering, did your buddy paint it with BC/CC or did he use a SS paint?
Old Sep 20, 2018 | 07:11 AM
Single stage catalyzed enamel has the same problem as BC/CC. You still can't flow out the final coat. That only works with lacquer.
Old Sep 20, 2018 | 07:28 AM
B964's Avatar
I've seen various colored panel painted cars come out great when done by a professional. Silver not so much. It's a tough color to even panel blend. I worked at a premier So Ca body shop with some painters that were true artists.
Your car looks really good. Get it outside and re inspect.
Old Sep 20, 2018 | 03:05 PM
Platinum69's Avatar
I think it looks much better outside
Old Sep 20, 2018 | 05:55 PM
Looks very nice -- but the panel you were most concerned about was the trunk lid, no? Got a shot of that?
Old Sep 20, 2018 | 08:29 PM
Platinum69's Avatar
It may be the way the light is hitting the decklid. The sun is shining in from the right. You can see how the different angle surfaces looks different than the flats.
Old Sep 21, 2018 | 04:53 AM
Did you pay your buddy to paint your car?
Old Sep 22, 2018 | 07:53 AM
Kensey's Avatar
This is the true question!
Old Sep 22, 2018 | 10:40 AM
Well, it does look a little different. As you say, from the picture it could just be the light. Regardless, tell the painter about your concern (ask him if he can see it) before the final rub-out and maybe he can address the problem.
Old Jun 18, 2019 | 07:26 PM
Jeff99's Avatar
Silver is a pain to panel paint. Did he spray the deck lid hanging or laying flat? That will make the flake lay different and Change the color, so does air pressure, temp, mix ratio ...
oldstofty
Dec 15, 2013 05:58 PM
kbdecatur
Nov 15, 2012 03:01 PM
Tom442
Jun 21, 2011 05:30 AM
71KUTLASS
Feb 11, 2011 09:00 AM
rennoc442
Oct 30, 2010 08:54 AM
