engine paint
Old Nov 23, 2009 | 12:15 PM
willj's Avatar
engine paint
hi , was looking for some input on using plain ole acrylic enamel with catylist, i have a bunch of red , thought it would work good for my 65 starfire ,thanks for any help,will.
Old Nov 26, 2009 | 09:58 AM
Dan Wirth's Avatar
I would use a heat resistant paint on an engine, that can be purchased at an auto paint store. The paint should be heat resistant to 600 degrees or better - the higher degrees the better. With regular paint, you can expect peeling PDQ, which presents a whole new set of troubles.
Old Nov 26, 2009 | 02:23 PM
442scotty's Avatar
I used PPG acrylic urethane on mine with a product called rust destroyer as a primer...No problems and no burn off for three years now...
Old Nov 28, 2009 | 05:25 AM
ijasond's Avatar
Purveyor of Polyurethane
I've seen several people use regular automotive paint on an engine block without any issues from the heat.
Old Nov 28, 2009 | 06:19 AM
Bobsw32's Avatar
BobsW32
Preparation, preparation, preparation.....With any paint job it is all in the preparation...........Yes it will hold up!
Old Nov 28, 2009 | 04:30 PM
willj's Avatar
engine paint
thanks to all for the input ,very helpful !
Old Dec 23, 2009 | 05:56 PM
patmills's Avatar
442forsure
How did you get your colour?
I am looking for the 400 Engine Bronze mixture ratio. I know SuperCars has it in spray cans but they say they can't get it across the border. I can get around this but would rather just get the paint here in Courtney if I could.
Old Dec 23, 2009 | 09:41 PM
78cutlass's Avatar
78cutlass
willj,
wassup buddy! how's your ride coming along? hey, whatever happened to the '69 SBO shortblock?
Rolo
Old Dec 25, 2009 | 06:57 AM
willj's Avatar
paint color
merry xmas to all,on the paint i used ,just plain ole duplicolor,high heat primer ,and high heat engine paint, took a piece of the engine paint i chipped off , and went to vip ,and napa, and matched with the cover ,came out pretty close .
Jamesbo
Paint
Jun 13, 2020 09:02 PM
jensenracing77
Paint
Sep 10, 2014 02:33 PM
JpMotorsports
May 15, 2014 07:08 AM
dlmsavings1
Sep 3, 2013 09:01 AM
805cut
May 3, 2012 08:11 PM
