engine paint
engine paint
hi , was looking for some input on using plain ole acrylic enamel with catylist, i have a bunch of red , thought it would work good for my 65 starfire ,thanks for any help,will.
I would use a heat resistant paint on an engine, that can be purchased at an auto paint store. The paint should be heat resistant to 600 degrees or better - the higher degrees the better. With regular paint, you can expect peeling PDQ, which presents a whole new set of troubles.
I am looking for the 400 Engine Bronze mixture ratio. I know SuperCars has it in spray cans but they say they can't get it across the border. I can get around this but would rather just get the paint here in Courtney if I could.
paint color
merry xmas to all,on the paint i used ,just plain ole duplicolor,high heat primer ,and high heat engine paint, took a piece of the engine paint i chipped off , and went to vip ,and napa, and matched with the cover ,came out pretty close .
jensenracing77
Paint
Sep 10, 2014 02:33 PM
JpMotorsports
May 15, 2014 07:08 AM
