68' trunk latch area body color or splatter paint?
Spraying a 68' 442 and wondered if the latch area inside the trunk is body color or splatter. Web searches show it both ways. I had the latch itself is re cad plated but I'd like to know what the support color is.
Thanks for any help.
This is a pic of my trunk latch area after I put a new floor in. You can clearly see trunk splatter paint inside. You can lightly see it outside however it mostly covered in primer. I am 99% sure that that no restoration work was ever done to the trunk prior to my restoration which began in 2003
It's a 04C Lansing 442 Convertible
Randy I noticed you don't have the wiring grommet next to your latch. Do you think it was always absent? The reason I ask is I also have a '69, low mileage original, and it lacks that same grommet. I figured it just disappeared sometime in the last 5 decades, but maybe it was never there.
Hi Brian, The grommet was there - I had just removed it because it was falling apart. I replaced it during restoration of the car. One thing I did notice with this car, however, is that the quality control was lacking. There were several attachment screws, and some bolts, that just weren't there. The stainless trim piece around the back of the convertible top was held in place at only 4 attachment points. My '69 has factory cruise control so the cable run for the speedometer is a little different. The opening through the firewall where the speedo cable goes without cruise control was just left wide open - it should have had a cover grommet. Then again, mine is a Fremont car and Fremont cars are not known for their quality control! I'm just glad it survived all those shortcomings!
Randy C.
Randy C.
