1978 cutlass supreme paint codes
I Was Wondering If Anybody Knows The Paint Code For My Cutlass It's Gray with a black vinyl top and factory black interior.i want to paint my car back to the original color it was im just adding a modern clearcoat to it
Your 'Profile picture' is called an Avatar. To set it up:
1. clik the 'User CP' on the drop down bar under the C.O. banner.
2. In Your Control Panel, choose 'Edit Avatar' under the Settings and Options section
Follow the on screen directions and browse through your pics to find the one you want to use, or paste in the URL you want.
Clik 'Save Changes'.
You can also install your signature line by cliking the "Edit Signature' in the same area of the User CP.
Hope that helps you navigate through what you need. If you run into problems either post or send a PM and we'll git 'r done.
